E85 Fuel Mileage on cammed fi 1kfwhp
Old 09-21-2017, 06:10 AM
romandian
romandian's Avatar
Originally Posted by Steve@C56
less flow = less power = less air = less fuel at same AFR
it's the idea
not sure if it will be better or not in cruise, but, perhaps
well, if crusing, that restrictor will be doing nothing.
Steve@C56 (09-21-2017)
Old 09-21-2017, 06:32 AM
Steve@C56
Steve@C56's Avatar
i was just an idea (or a hope lol) :-(
Old 09-21-2017, 08:27 AM
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
Originally Posted by romandian
well, if cruising, that restrictor will be doing nothing.
^^ He's right. Only restricts the top end, not the bottom. Milan's right too. Your 02's switch where they're set to. You can do open loop cruise and save a bit of fuel. I suspect that cruising @ 60mph will save over cruising @ 75-80, but what fun is that?
You can also do a mix of open and closed loop. Open loop cruise and closed loop idle if you choose.
Reducing your timing will negatively affect your mileage by creating lower power for the same given fuel charge.
The only idea I have for you beyond what the others have shared is to get a small trailer and load it up with fuel and try hyper-miling by drafting big trucks down the highway
I hate to say it, but I hope over spinning your V3 works out for you. If not, you can split the case open and convert it to engine oil fed and take out the oil slinger.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Old 09-21-2017, 08:59 AM
Steve@C56
Steve@C56's Avatar
I will do some 02 mods test this weekend
A 60mph cruise is A LOT boring on a 1000fwhp car, specialy a +300miles cruise lol
For timing, it was what i was thinking... and it s why i have test huge timing before going Z06 based map
I overspin the v3 since 2013 or less, and it was my DD, V3 rock... (for now)
Did you think engine oïl is better than expensive special vortech oïl ? (who look like dextron, but it's another story)
Old 09-21-2017, 09:35 AM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
So, i cannot understand how some guy can claming good fuel mileage with big hp car.
I will test restrictor if i can find a machnist close to my house ^^.
Don't see this helping on MPG, Plus don't see pulling timing out will help at all if anything will do what you don't want it to do.
On timing every car is a little diff even with the same set up & parts in it. Find the cars sweet spot in that and keep it at the level are deg's.
Old 09-21-2017, 10:36 AM
algZO6
algZO6's Avatar
Did we have a unicorn V3 on my car? LOL We spun the sh*t out of that thing and its still going strong with the 3.125 pulley.
Old 09-21-2017, 12:06 PM
neverstop
neverstop's Avatar
honestly 11-12 mpg on the freeway for a 1000hp car seems pretty damn good to me?
even if you improve that by 25% though which would be huge you're still not going to make your event the way you are describing so seems like a waste of time to try? it's not like your car is ever going to get 25mpg on e85 no matter what you do.
I'm sure there will be other people with trucks and trailers at your event, if it were me I would just offer to buy one of them dinner or beer and ask them to bring you 20 gallons of e85 you can drop off with them ahead of time and then can just put them in their trailer or something. I've done this before when had no room for stuff in my car.
I would imagine that adding a restrictor will do nothing
Old 09-21-2017, 04:37 PM
Rkreigh
Rkreigh's Avatar
you right, easy to flex fuel afr (just by write someting exactly between 9.7xx and 14.63 afr, and O2 does the rest in closed lood)
but difficult for flex timing, as i'm 11.1 CR and quite always in boost (little blower superoverspin)
absolutely correct timing tables would be different, but if you stay conservative on the street, and set on "kill" at the track with e85, I think you'll be much happier in the long run with a car you can take out on the road without worry
e85 is availalble but getting stuck without it is no fun and the flex fuel does just fine for 90% duty
I agree that for best results, the flex fuel tune is a compromise at best, but it sure beats walking down the side of the road
ask me how I know.
Old 09-21-2017, 05:14 PM
Supporting Vendor
if I'm not mistaken, since the days of yours, they either added the slinger or changed the way it attaches and it's composition and it was a big fail. Word from beyond is that they took a closer look at this and are changing it for the better or already have done so.
Old 09-22-2017, 08:25 AM
Steve@C56
Steve@C56's Avatar
Better that restrictor plate (who just limit the flow and the power at a certain point), a bypass valve...
Think about ZL1 and ZR1 PD SC... they have a bypass valve to reduce the operational load of the supercharger on the engine (and also reduce internal supercharger temperatures since air is not being compressed needlessly)
The bypass valve reroutes intake air from before the sc rotors to after the sc rotors so the extra air isn't compressed and bypasses the sc
This reduces boost and save fuel for sure
So, what about unmount the valve in blow off valve whene 100% cruise trip ?
See this : https://www.google.fr/url?sa=i&rct=j...06165455173008
(calc inside)
V3 Si show 2.9psi at 2.387rpm, and 7.6psi when concervative psi for stock high CR application (3.8" pulley and 7.33" damper for LS)
I'm 3.125" and 8" OD, so, when i cruise at 1800rpm, my sc hit the same psi than graph show at... 2388rpm... so, 2.9psi (at 1rpm diff lol)
As NA is 14.5psi... my engine "eat" 17.4psi, so it's 20% more air (and fuel)
So, open blowoff should save exactly 20% fuel (in my theory)
And it's a way easy ^^ perhaps just noisy (shhhhhhhhhhhhhhuuuuuuuuuuuuuuuuuuuuuuu) lol
Old 09-22-2017, 08:55 AM
Pekka_Perkeles
Pekka_Perkeles's Avatar
Go back to the basics of internal combustion gasoline engine.
Limit the airflow with the throttle.
As much as you want. It is there for that exact reason. :-)
Old 09-22-2017, 12:32 PM
romandian
romandian's Avatar
ethanol doesnt mind being run very rich, which is good for cooling. does anybody know how lean it can be run (safely)?
Old 09-23-2017, 01:13 PM
  #33
FourG63 97GST
FourG63 97GST's Avatar
what's the end goal here? for me it's was still cheaper to daily drive on E85 vs 93, when it came to fuel economy, mathematically it was about 6cents cheaper/mile to run E85
Old 09-23-2017, 05:01 PM
  #34
leo12
leo12's Avatar
Originally Posted by Milan
180-200 mile a tank
you are correct my friend,i get a kick with some of these guys with over 800-850 RWHP posting 20-25 MPH ,Funny stuff
Steve@C56 (09-23-2017)
Old 09-23-2017, 06:41 PM
  #35
Steve@C56
Steve@C56's Avatar
But force induction is force induction !
Old 09-23-2017, 06:47 PM
  #36
Steve@C56
Steve@C56's Avatar
drive 350 miles for drag race without any E85 station... and expecting use more than 20 gallons on the dragstrip during 3 days race
Old 09-23-2017, 10:12 PM
  #37
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
can you not have someone follow you there with a truck and a few barrels of fuel?... or put a hitch on the c5 and rent a small uhaul trailer
Steve@C56 (09-24-2017)
To E85 Fuel Mileage on cammed fi 1kfwhp
Old 09-24-2017, 01:25 AM
  #38
Steve@C56
Steve@C56's Avatar
some dont go to the strip...
others have not place...
others tell me "sorry, i'm not take any fuel barrels because too risky (leak, smell, explosion like in the film... all raisons who exist in the world")
others dont respond (and, at the track, will probably tell me "oh, how re you, fine ?")
others live far away from me
and in fact, as it's the last dragrace of the year, it's a special event as they have to cancel the normal last (normaly, last race is 1st weekend of september), and realy a few French (i live there) racers want to go a this race in Italy (another country)
i probably find somebody if i ask individualy to all person i know, but it will be the same boat next time, so i'm lookling for an solution to my self
Old 09-24-2017, 04:32 AM
  #39
Pekka_Perkeles
Sure, but you can't compress something that isn't there....at least with the PD. :-)
Old 09-24-2017, 04:35 AM
  #40
Steve@C56
Steve@C56's Avatar
Sure, but you can't compress something that isn't there.... :-)
I'm not PD like ZL1 or ZR1, i'm Vortech SC, so, SC compress BEFORE TB
Quick Reply: E85 Fuel Mileage on cammed fi 1kfwhp
