oil drain locations
oil drain locations
So i dont have my engine or any parts to mock something up right now but im planning my twin turbo build and i wanted to know what my options were for the drains. I had a single drain before on the front driver side oil pan right below and to the side of the crank pulley but i wasn't sure if there was enough room on the passenger side for a second one? I will be putting my alternator down on the passenger side as well so i will need to make sure i keep the A/C tensioner down there for the belt but wasn't sure if anyone had a picture or if they have used that spot before? Just trying to find my 2 spots for the twin turbo drains. Turbos will be mounted high with some up and forward headers.
Ict makes a front timing cover that has two an fittings welded on the bottom of the covering either side. It's pretty sharp. I'm currently in the op's situation but I really don't want to take off my timing cover and balancer. Hope that helps and bump for any other twin turbo drain locations.
