ysi 4 inch intake aluminium intake pipe ( 45degree or 90 degree ) ???
Im ordering some 3.5 aluminium piping to do my custom intake pipe from I/C to TB with some welding bung to add 2 meth nozzle and the Iat sensor.
Since im there i would like to order a 4 inch intake pipe to replace the plastic dongle.I got a dewitts cut down and using some custom cradle spacer so everything should fit.
Do i need a 45 degree or a 90 degree pipe ???
I used a 45* on my old T trim setup, could probably use a 60*.
always faster (11-08-2017)
This is a 45...
Thanks for the answer, i would like to keep the filter under the shroud so 60 degree it is
