Wideband AFR
Full time I run a pair of NTK sensors for my Syvecs ecu, 1 in each pipe around 18" after each turbo.
Over the years etc though I've tried a few different things with widebands. I still run a Bosch LSU4.9 in the left pipe just beside the NTK one for an independent gauge.
I have 2 lambda bosses in each exhaust so I can easily mess about.
I've never run narrowband sensors....because there isnt much point with an aftermarket ecu.
So I bought the Aem Uego X series, and have a couple of questions;
Is there some kind of max/min reading on the unit itself, can you after a pull look at max/min values on the display without logging?
What is the simplest way to log, are there any "gadgets" that do just that or do you have to connect a laptop, Hptuner etc?
Max/min would be totally irrelevant because the info has no value without context...
ie exactly when it occurred, under what driving conditions/load etc...and the extremes of any readings would never really fall when they actually matter.
Easiest and best way to log is via the ecu. I dont use factory ecu's so cant comment as to what they can or cannot log and how easy/hard it might be. I'm sure there are plenty of others here who can advise there.
AEM should offer a logger of some sort too ?
Simplest and least technical....set up a video camera to watch the gauges as you drive. Or even less technical...watch them whilst you drive, with the caveat of not crashing.
The GoPro logger, that was a good tip!
Another thing, tip where to pick up 12V ignition switched, and where did you thread the cables into the cockpit?
For wiring...again you'd need to speak to a Vette owner as to what is best.
At least we have small cameras these days...I recall 20+ years ago using a VHS-C to record some gauges ! lol
You can get 12V switched from the passenger foot well. There is a wiring pigtail stuffed up in there with the BCM module with a orange, yellow and black wire. The yellow wire is your 12V switched.
