Dewitts radiators
Old 11-23-2017, 09:09 PM
TheBigDog
TheBigDog's Avatar
Default Dewitts radiators
Just went to dewitts site and they have a direct fit unit with an oil cooler built in. Is any one with an FI car running this radiator? What are your results? Thanks
Old 11-23-2017, 09:36 PM
silver408z
silver408z's Avatar
Lots of people run dewitts and its supposed to be good stuff. Some people smarter than me don't like oil coolers built into the radiators. Puts even more heat into the coolant and just that much more work to keep the car cool. A separate cooler is the way to go for the oil.
Old 11-23-2017, 11:18 PM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,260 Likes on 1,055 Posts
I have a full size dewitts in mine for the last few years with spal fans and it has worked great... I chose the one with no cooler for the reasons mentioned above plus you get more cooling capacity if you ditch the built in cooler
Old 11-24-2017, 12:14 AM
ZYOUL8R
ZYOUL8R's Avatar
I have the full size Dewitt's and used the stock fans. Temp Stays at 185-190 sitting still with the AC off. With the AC and sitting still it will get up to 210-220 but drop down once you start moving. This was through the Alabama summer.
Old 11-24-2017, 02:02 PM
TheBigDog
TheBigDog's Avatar
Thanks guy I was wondering about the radiator and the stock fans. That is the way I heading.
QUOTE=ZYOUL8R;1596032990]I have the full size Dewitt's and used the stock fans. Temp Stays at 185-190 sitting still with the AC off. With the AC and sitting still it will get up to 210-220 but drop down once you start moving. This was through the Alabama summer.[/QUOTE]
To Dewitts radiators
Quick Reply: Dewitts radiators
