NX Express purge valve failure
I'm working on getting a better line ran for my purge valve. Someone suggested an oil pressure line that is copper. I ran this and use the purge once and it went off. I tried to do it again and nothing happened. I traced wiring, I ohmed it out and used a test light for voltage, everything checks out.
I noticed the nut was loose on top and I tightened it down. Still didn't work. I did notice my battery voltage was around 10 volts. Would this prevent it from going off or is the purge solenoid bad? It's 2 years old and maybe used 20-30 times.
Solenoids of any kind are very sensitive to voltage fluctuations. It probably doesn't have the strength to open/close with anything less than 12V
