Boost gauge reading vacuum but not boost
Old 01-19-2018, 05:55 PM
Uassaide
Uassaide's Avatar
Default Boost gauge reading vacuum but not boost
I have a c5 z06 corvette with a A&A super charger kit, I installed a tee in the brake booster line that feeds into a vacuum block & hooked up my blow off valve, boost gauge, & BAP to it,
For some reason my gauge shows vacuum @ about 25hg but when i drive the car the boost needle does not pass 0 psi. Any ideas why?
Thanks!
Old 01-20-2018, 12:40 PM
StatmanRN
StatmanRN's Avatar
What type of gauge are you running? Electrical sending units can be problematic, wspecially with cheaper units.
Start by cleaning the contactss and connections. You can also use a T fitting with a known value gauge pref mechanical to verify it.
Old 01-20-2018, 06:02 PM
stevieturbo
stevieturbo's Avatar
Thanks!
Get a mityvac and test....
if you've all those things hooked up to a line to the brake booster....which may have a check valve in it, potentially none of those things will be seeing positive pressure and none working correctly.
Old 01-20-2018, 06:57 PM
Uassaide
Uassaide's Avatar
Im using a glow shift mechanical gauge.
Old 01-20-2018, 07:15 PM
Uassaide
Uassaide's Avatar
Jeez thats so weird, i think this is a check valve directly going into the brakebooster itself, i dont understand why The A&A instruction manual would tell people to hook it up there
Old 01-20-2018, 08:51 PM
itsslow98
itsslow98's Avatar
This is probably the problem. Glow shift is complete junk.
Old 01-20-2018, 09:03 PM
Uassaide
Uassaide's Avatar
Haha im starting to see that. I will order a AEM one and hopefully that will take care of the issue.
Old 01-20-2018, 11:03 PM
bahamasair
bahamasair's Avatar
Put the t on the other end of the brake booster hose. I’m guessing you’re on the wrong side of the check valve. You will never see boost if that’s the case.
Old 01-21-2018, 06:11 AM
stevieturbo
More probably instructions not followed correctly, rather than them being wrong or everyone would be having your problem
To Boost gauge reading vacuum but not boost
Quick Reply: Boost gauge reading vacuum but not boost
