Hit 160.84 in the 1/4
Received 1,762 Likes
algZO6 (02-06-2018)
ttt
Albert car looks like you had her on rails. Robert
algZO6 (02-08-2018)
algZO6 (02-09-2018)
algZO6 (02-11-2018)
What is the best it’s 60ft? And 1/8? Id like to build a 5.6 setup but not sure what’s needed to make that happen. We’ve been 5.50s in a 3800lb camaro that makes 900ish. Not sure if you can do that with a vette
#35
definitely the converter. this triple just doesn't work as well as the single i had. it should be back at FTI any day now for a re-stall. track also wasn't that great which cost me some ET as well. i am going to switch out to the pro bracket radials. been doing some recon and supposedly they are the bees knww.
C5 Pete (02-13-2018)
#40
