The Race Engine Shop Short Or Long Block Sale
Former Vendor
Internet add - individual priced. Fully Forged GM Gen III or IV LS Series Short Block. Pictures are representations of some of engines we have built. Price includes a used structurally verified and Clean Iron 4.8/ 5.3 block ( approximately 326 - 383 CID depending on parts selection). Other blocks and components are available and listed below. This is not everything we offer. We can do Just about anything you want to do.
Parts List
•5.3 Iron Block (Seasoned Core)
•Durabond Cam Bearings
•ARP Pro Series 8740 Material Head Stud Kit
•ARP Pro Series 8740 Material Main Stud Kit
•K1 Technologies 6.125" Forged Connecting Rods With ARP2000 Bolts or Callies Compstar Connecting Rods
•K1 Technologies 3.622" or 4.000" Stroke Crank with 24 or 58X Reluctor
•Wiseco (2618 Material ) Forged Pistons and Tool Steel Wrist Pins with A Ductile Iron Nitrided Steel Top and Napier Second Ring Pack.
•New King XP Series Tri Metal Main and Rod Bearings
BTR shelf or custom Camshaft, LS7 Lifters And Trays
•Elite Adjustable Timing Set
Machine and Assembly Labor Plus Extras
•Block and Crack Checking on all new and used Cores
•Block Pre Machine Cleaning Deburring
•Prime and Painting with VHT Engine Enamel, Red, Black or Orange (Other colors Available at Cost of Paint)
•Align Hone the main housing bores
•Cylinder Boring (If Necessary)
•Torque Plate Cylinder Hone with Plateau Finish
•Block Decking and Quench Distance Setting
•piston and Rod Pin Fitting and Big End Sizing (If Necessary)
•Crankshaft Blueprinting (Checking For Straightness and Correcting if Necessary)
•Crank Balancing (heavy metal not included)
•Block and Component Final Cleaning And Final Deburring
•BluePrinting of Block and Components
•Block Plug Kit Installation
•Final Assembly.
Price Includes all associated Labor with block and hard parts purchased through The Race Engine Shop. Customers are welcome to send their own parts but additional charges MAY BE assessed on a cast by case basis. The following includes but are not limited to examples of customer provided parts extra charges. Pin Fitting, Rod Resizing, Crankshaft checking, Crankshaft Balancing, or any correction to components deemed necessary by the Race Engine Shop for a suitable engine.
Contrary to popular belief, all shops ultimately charge for blueprinting. Some will lower their price by eliminating steps (such as blueprinting) as it saves time. Time is money! One of the most common steps eliminated is blueprinting itself. A vast majority of blueprinting is to verify tolerances of components that the engine builder does not produce. We would rather keep you out and running then having problems because we wanted to save a bit of time and pocket a few extra bucks. “We are not interested in selling a steak and delivering a hamburger if that makes sense”
Some things to pay attention to and components to NOT get caught with when shopping for a high performance engine.
approximately 30 days depending on any additional parts selected and their availability.
•How Much Power Will The Engine Support
that’s largely dependent on the engine management calibration and parts selection and induction type among most things. On an engine like the one above; it should be able to support 1200 HP. Yes I understand there are people out there with bone stock bottom end 5.3L engines making astronomical Power. All it tells me is that they have got away with it to this point. Those are ticking time bombs and most of the people who do that kind of stuff usually understand that. Building a high performance engine isn’t about getting away with Something. Rest assured when you make big power, the BS is coming. Get your self an engine that will take the BS head on.
The Total For The Above Engine as Listed is $6,027 plus shipping. I like to use fastenal’s 3PL Program for shipping. The cost of materials and time for me to build a crate is $140 (not included in price)
All the following prices are for parts upgrades and would be added to the total for the above engine <—— pay attention to this. Seriously!
Oil Pump Camshaft and Accessories
Melling oil Pump part number 10296 +156
Pushrods +110
Engine Block Options
(Used Cores Available for most blocks at a significantly reduced price market value dictated)
New Iron 4.8/5.3 Block +300
New Iron 6.0 Block (Gen 4) +1,126
(Gen 3 Available reconditioned Core only) +600
Aluminum 5.3 Block used Core only +200
New Aluminum L92 / LS3 Block +1695
New Aluminum 6.0 LS2 Block +1,264
New Aluminum LS7 +3,177
New Rotocast Aluminum LS9 Block +3,835
New GMPP LSx Standard Deck Block +2,730
*New Dart SHP Pro Iron Block. +2,407 (requires different head Stud Kit) and requires Block parts kit. (Pro Block Not Available yet but Standard SHP is Available now)
Adjustable Timing set with heavy duty chain +130
Piston & Ring Options
Custom High Boost or Nitrous Piston Kit includes proprietary sized AP Stainless Ring Pack specifically for those running high boost or high amounts of nitrous. +700
Crankshaft Options
Callies Ultra Billet 4330VM Timken Steel Crankshaft Center Counter Weight Crankshaft (Includes Center Counter Weight Block Clearance) with engine Build) Stoke 3.500” and under +2,068
Callies Ultra Billet 4330VM Timken Steel Crankshaft Center Counter Weight Crankshaft (Includes Center Counter Weight Block Clearance) with engine Build) Stroke Over 3.500” +3,131
Callies Dragon Slayer Crankshaft +934 3.625” - 4.125” Stroke in incremental stroke sizes.
Dart 4340 Billet Center Counter Weight Crankshaft 4.000” or 3.600” Stroke (Includes Center Counter Weight Block Clearance) with engine Build) Available in long snout for factory dry sump application. +532
Callies Compstar Crankshaft 3.625” or 3.622” Stroke +203
Connecting Rods
Callies Compstar H-Beam Rods with ARP 2,000 Bolts +360
Callies Ultra H Beam Rods +600
Callies Ultra Billet I Beam Rods 4330VM Timken Steel +1,169
Wiseco Boostline Rods +619
Fastener Options
Callies MP 3.5 Rod Bolt Upgrade (Callies answer to CA 625+ Material Rod Bolts) really good stuff. Needs to be ordered prior to ordering Rods. +440
ARP CA625+ Head Stud Kit (Non 6 Bolt Heads) +455
ARP CA625+ Head Stud Kit (Non 6 Bolt Heads 1997 -2003 multi Length) +551
ARP CA625+ Head Stud Kit for 6 Bolt Heads +601
ARP CA625+ Main Stud Kit. +411
Dart SHP Block pre Pro Series SHP Block Main Studs (Only 8740 Material Available) +136
ARP2000 Head Stud Kit For (2004 and Newer + $154
[img]file:///80-photo_4_7ddf2b0af7e0b79deeeb87b772242856 fae42732.jpg[/img]
[img]file:///80-photo_2_2a79bc0549cf932e5612c35f652b565c 05cfb81a.jpg[/img]
[img]file:///80-photo_1_9f013bd097345ff9db4854e1a2e17435 7a95a18f.jpg[/img]
[img]file:///80-photo_3_ad9c3a5c2b364bcce7365d578fc4a319 f5c2841c.jpg[/img]
[img]file:///80-photo_5_06a3cc74cb10df63959cd2becd26d1da a286702a.jpg[/img]
[img]file:///80-photo_6_a4babe35bd87db1f40c75e58a7e04873 6905d1ca.jpg[/img]
[img]file:///80-photo_7_280993d98af2195f7a26d52cc7627d24 62299ed4.jpg[/img]
[img]file:///80-photo_8_d8a01f4eab1d5f565bf6e606175b6572 5abf94a3.jpg[/img]
[img]file:///80-photo_9_18e8d34a6b027c9150dd12acc51e358b dd6331bf.jpg[/img]
[img]file:///80-photo_10_cf26943cf398fe39cbfbb539fc97027 57c3a13b2.jpg[/img]
[img]file:///80-photo_11_e8e2188e99b80f38154155c67d70b20 c21b6f8ce.jpg[/img]
[img]file:///80-photo_12_1aff6e1910fe08bfe90ea8b13528426 532312ec0.jpg[/img]
[img]file:///80-photo_13_d6b91ae5a06a5c2df0c6cc40026f991 eb20b6d53.jpg[/img]
[img]file:///80-photo_14_6733e997d8bb8059816c3c5f30735e3 471e0ef88.jpg[/img]
[img]file:///80-photo_15_dcfeb36192f30a0a61668a21081a6d3 32c770d50.jpg[/img]
[img]file:///80-photo_16_d6daabfe2f08266f014f1bd73ad1908 83a3e18c1.jpg[/img]
[img]file:///80-photo_17_eb10a2f66a5bab00a1b1bdb3a507874 6059997e5.jpg[/img]
[img]file:///80-photo_18_2117a24827c177bee7f45e03bf9f908 81b8f8e07.jpg[/img]
[img]file:///80-photo_19_245b815a7f955676e918f51be6c008d f41d9e562.jpg[/img]
[img]file:///80-photo_20_11e9a9823b33ea2755b37e7a64b1a94 337f536c8.jpg[/img]
[img]file:///80-photo_21_ce3b5d4dd30f44044eac2c41f5394db 2fcfbc293.jpg[/img]
[img]file:///80-photo_22_7478e83e08d8faf621ed9339bcc99e7 0d9123470.jpg[/img]
[img]file:///80-photo_23_018b496468045b8110f648b70711576 e375a6c1f.jpg[/img]
[img]file:///80-photo_24_ff352a72158fb51c3a3073be610ff85 481c1e104.jpg[/img]
[img]file:///80-photo_25_2ae056812daf260a0c5c5c275e9864b 0a8dd96ca.jpg[/img]
[img]file:///80-photo_26_670c9de8a359072ed3fb89036e5a559 341f4e34c.jpg[/img]
[img]file:///80-photo_27_9704dcb2718eb89c352a293ef3be152 2f9d6919b.jpg[/img]
[img]file:///80-photo_28_5e3a96da8b701682de63b0970f88ffc d2378201b.jpg[/img]
[img]file:///80-photo_29_fcbbaf0ae1216cf29d8eae2e75dbb04 b983435ea.jpg[/img]
[img]file:///80-photo_30_86ab9cef251c5be9b8c22fac2443e5b 05d96ce9a.jpg[/img]
[img]file:///80-photo_31_9ef84b857561c8196e039420651fd3c 5656fba5d.jpg[/img]
[img]file:///80-photo_32_a2746265c49c21fb8cd302a1e110f91 7ed48b56e.jpg[/img]
[img]file:///80-photo_33_22b22c52b9c426b94565866bf01b78f 130985617.jpg[/img]
[img]file:///80-photo_34_4971865cd9cc0b4b0eaf44231093202 fa4862c58.jpg[/img]
[img]file:///80-photo_35_b261539f8ddfc9944a48bbc1649a7e3 50217f456.jpg[/img]
[img]file:///80-photo_36_af77c89a5f2d69c931220773e00da58 c8df587da.jpg[/img]
[img]file:///80-photo_37_91b9280911667feb8babdb96a244239 1597f7b95.jpg[/img]
[img]file:///80-photo_38_9fcb46c013d9cf2d463fe8cedd08107 d2a4fa161.jpg[/img]
[img]file:///80-photo_39_871721bd0cca2727caac1bffd7f5b6a 7f87fffa2.jpg[/img]
Parts List
•Final Assembly.
- Bearing Type don’t get caught with a bearing that’s made aftermarket manufacturer such as King, Clevite, Ect. but it’s only a Passenger (P Series) Bearing. P Series Bearings are not designed to take the high loads of a high performance engine. The High Performance (H Series) Bearing is.
- Wrist Pin and Piston Rings Don’t get caught with standard wrist pins which most of the manufacturers only rate to 700HP (that’s flywheel HP). In addition, don’t get caught with piston rings on nice pistons.
- Inferior Fasteners for critical components (Especially In Connecting Rods) Don’t get caught inferior 8740 material rod bolts in your high powered engine. I’m not saying 8740 Material is bad. It has its place in a high performance engine. I’m saying there’s better material available (at a slightly higher cost and The rod bolt is the most stressed fastener in the engine, it shouldn’t be overlooked. Most of the aftermarket rod manufacturers don’t even offer 8740 material rod bolts in their Connecting Rods for these engines and there’s a reason for it.
- Warranty Pay Attention to what warranty means. No high performance engine builder offers a warranty on their engine perse! I don’t care what they write or say. What a lot of builders do, (myself included) is stand behind our work. What that generally means is if there’s a problem that we caused, we stand behind it. More importantly as a builder I’m not completely unreasonable either. I’m a human being and I understand things happen. I don’t mind working with people what I mean is customers deserve good honest and fair treatment. Weather you spend $100 or or $100K
Pushrods +110
Crankshaft Options
Connecting Rods
Fastener Options
Former Vendor
Here’s a LSx Based 427 CID Engine I built for Greg’s Magnacharged C6 Z06. It also has some Spray just because. It made over 1,000 Wheel HP. The Car was Built and Tuned by Corvette Forum Supporting Vendor BlownBlueZ06@RKTPerformance
Hey that beautifully built and wrapped LS2 with the ugly red valve covers is mine! Bump for Mike, you will not be disappointed working with him.
MVP @ TheRaceEngineShop (02-09-2018)
Former Vendor
Former Vendor
Current Inventory of blocks ready to machine and assemble
(2) LS2 aluminum blocks
(2.) Gen 3 4.8 / 5.3 Iron Blocks
(1) Gen 3 6.0L Iron Block
(1) Gen 3 6.0L Iron Block will be .030 over.
(1) Gen 4 4.8/5.3 Iron Block
(1) Gen 4 4.8 / 5.3 Aluminum Block
(1.) LS3 Block.
(1) Gen 4 4.8 / 5.3 Darton dry Sleeved Aluminum Block 4.125” Bore this one is $1,100 for the block.
If you act now I will give you 15% off the listed price for any of the block core prices.
(1.) LS3 Block.
Received 1,762 Likes
ttt
Bump for you buddy I don't need to be looking in here no more. Nice clean shop & work. Robert
Former Vendor
beautiful stuff there!
here's my build, and I'd love to get some advice using a TTix turbo kit with the stock turbos, thinking of .82 exh housings and champion downpipe, adapting c6 z06 3" exhaust sytem.
4.8 l33 block, I'm debating on the stroke ?
I have a 4.0 lunati forged crank, lunati rods
buying pistons, and wiseco makes a nice 3.80 that will work with 4.0 stroke
what concerns me is two things, the bigger stroke puts displacement up there which might be choked past 6k by smaller turbos
and a stock 3.22 or 3.6 crank might work better (pistons won't come out of the bores).
I'd love to be able to afford an ls next block, looking for a deal on one!
you all do some nice work and turbo ls engines are the best!
Former Vendor
heres the thing. Piston design is going to play a role here but for all practicle purposes we are able to put the piston where we want it. To keep the parts stack in the same location relative to the deck going from a 3.622” Stroke to a 3.600” stroke would require a rod that is .011” longer or a piston with .011” more Compression Height. Changing the piston diameter, compression height or in most cases, the piston volume of a shelf piston usually isn’t a ton more in piston price. Where it gets heavy in price is when you start making ring groove changes and things like that.
The thing about building these engines is that no matter how we look at it, the BS is coming. So instead of making the main focus on building an engine and seeing what we can get away with, it’s usuallt more cost effective in the long run to build something that has the best chance of taking the BS head on. Though I will agree that the tune up of an engine plays a heavy part in the survival of an engine, it’s not everything. One of the things we like to do to help take the BS, especially on these boosted engines is pay attention to our piston rings. This is more than say just throwing an AP Stainless or Tool Steel ring in the bore and letting the combo eat. We put some serious time and effort into dialing in these ring packages. (We aren’t the only ones to do it but one of the few who actively pay attention to it) As far as the turbo size goes, in my opinion it’s usually cheaper to buy different turbos than an engine so if you want a larger engine even if the turbos are initially too small, it does make sense to me to build the engine you want and upgrade the turbos later. Just my opinion. Also certain cooling mods that can be done to help. (Another thing we aren’t the only ones to do but one of the few who actively do it)
one of the other things we are actively working on is oiling system modification. (To my knowledge we are the only ones doing this on this platform). Wish I could give more details but right now I can’t. Maybe some day I will.
