Twin to single turned turned full build
CF Senior Member
What type of turbo are you running? Oil restrictor on the feed line if its ball bearing?
Is the catch can filling up while you are driving as well?
CF Member
Brand new Borg T6 s475 no restrictor on the feed and a -10 drain. Also, the oil on the dipstick is already almost black with less than 100 miles on the change.
