Stock C5 ls1 a&a v3 ti. What pulley size and fuel system?
Old 04-19-2018, 04:36 PM
greg121121
Cruising
greg121121's Avatar
Default Stock C5 ls1 a&a v3 ti. What pulley size and fuel system?
I've got a stock 2000 c5 (stock exhaust, heads, cam, intake, everything), and I recently picked up an A&A V3 Ti supercharger. A couple questions:
1. What's a safe hp to run it at? Looking at forums maybe 550rwhp?
2. What pulley size would I need? I got a 3.6 with it, but I'm assuming that won't work.
3. Can I get away with running a racetronix single fuel pump with hotwire kit or do I need to add BAP? Or something else.
Trying to keep costs down as much as possible. Thanks
Old 04-20-2018, 01:57 AM
CorvetteC5Norway
CorvetteC5Norway's Avatar
I've got a Novi 1500 kit on a stock 98, same SC as you. I have upgraded in-tank fuel pump with no BAP. ECS recomended to go with new fuel pump instead off BAP, the stock pump is getting old...
As for the pulley, my kit is with a 3,5 pulley AND a restrictor in the intake. That makes approx 10 psi. I've heard that 3,5 and no restrictor makes 13-15 psi.
If you limit yourself to approx 10 psi, you will probably make around 500 whp. I'm just shy of that having turned down my rev limiter to 6000 rpm. Hoping to be on the safe side :-)
A tip - remove foglight shrouds and install Z06 grille mesh. Did wonders to my coolant temps.
Old 04-20-2018, 08:31 PM
RedRiderZR1
RedRiderZR1's Avatar
I have this exact setup. The 3.6 pulley will give you 9-10 lbs boost and after tuning around 550rwhp. Lots of cars running that pulley. The pulley A&A puts on the LS1s. Very reliable with that pulley. As for the fuel pump, the racetronics fuel pump will do just fine. No BAP needed. That's how my car is setup and have been running it that way for 9 years now. Install it as you have it and have fun. Longevity of the setup comes with a good tune. That is the critical part. Also, what injectors are you running?
Old 04-20-2018, 09:17 PM
NSFW
NSFW's Avatar
With a Ti and a 3.6 pulley, at what RPM do you hit that 9-10psi boost level?
Also, is it practical to limit top-end boost with wastegate/blowoff-valve and a manual boost controller, rather than with a restrictor? It seems like that should work, and should be easier to adjust, but I don't see people doing it, so I wonder...
Old 04-21-2018, 02:53 AM
greg121121
Cruising
greg121121's Avatar
I bought 60lb injectors for it.
Old 04-23-2018, 05:19 PM
greg121121
Cruising
greg121121's Avatar
Thanks for the posts. Anyone else have any feedback?
To Stock C5 ls1 a&a v3 ti. What pulley size and fuel system?
Quick Reply: Stock C5 ls1 a&a v3 ti. What pulley size and fuel system?
