C5 Z06 ECS Kit Novi 1500 Looking for 800 WHP + what’s next?
Old 05-13-2018, 09:46 PM
Khorton123
5th Gear
Khorton123's Avatar
Default C5 Z06 ECS Kit Novi 1500 Looking for 800 WHP + what’s next?
Hey there,
Brand new to the forum
I have a 2003 Z06 with
Texas Speed Headers
ECS 1500 Kit (polished)
Billyboat Exhaust
McLeod RST 800 HP Clutch
10 PSI
591 RWHP 534 RWTQ
Thats it
Car has 85,000 miles on it
What are the next steps to getting myself to 800 WHP?
Just testing the waters here. Fuel system and forged internals plus more boost? What do y’all think
Old 05-13-2018, 09:52 PM
ysb02
ysb02's Avatar
T6060 and c6 z06 rear so your transaxle doesn’t grenade.
Old 05-13-2018, 10:28 PM
silver408z
silver408z's Avatar
You are going to need a fuel system most likely, meth if you are not e85, a cam, injectors, a direct drive setup would be to help fight belt slip, smaller pulley for max rpm on the blower and maybe heads.
Old 05-13-2018, 10:33 PM
Khorton123
5th Gear
Khorton123's Avatar
my bad I forgot I have a BTR JAM Cam
Old 05-13-2018, 10:34 PM
Khorton123
5th Gear
Khorton123's Avatar
what does it take to switch over to E85 in terms of $
Old 05-13-2018, 10:49 PM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
take the restrictor out if you still have it, more boost (smaller pulley), secondary drive with overdrive balancer, and a fuel system... you can either do 93 and meth or e85... there are plenty of good e85 stations around the area so if you aren't driving it a ton or doing road trips then it would be a good option... talk to Bret and he can get your tanks setup with twin walbro 450s... stock heads/intake/throttle body will make 800+ so you don't really need to mess with those in my opinion
Old 05-13-2018, 11:04 PM
Khorton123
5th Gear
Khorton123's Avatar
what’s the total cost with labor round about with what you’re suggesting? I’ll have to ask if my restricter plate out
so let’s say restrictor plate out, E85 swap with new fuel system installed.
What you reckon that runs a common man
Old 05-13-2018, 11:51 PM
69GTO96Z
69GTO96Z's Avatar
My car is a stock crank forged rod/piston 347. Ported 243 heads, jam cam, ls6 intake, dual nozzle meth, YSi with 8 rib direct drive. At 15 psi the car made 798 on a loaded mustang dyno, tuned fairly conservatively on 93.
Old 05-14-2018, 12:01 AM
Tusc
Running Guns & Moonshine
Tusc's Avatar
Received 3,284 Likes on 1,938 Posts
About tree fiddy.
Sorry, man. I had to.
BoostedONE35 (05-16-2019)
Old 05-14-2018, 07:53 AM
Khorton123
5th Gear
Khorton123's Avatar
For the Forged rods/pistons, and ported heads what did that cost? This would be my goal if I can afford it.
Old 05-15-2018, 06:59 PM
0MVP @ TheRaceEngineShop
Former Vendor
MVP @ TheRaceEngineShop's Avatar
Though people make more than 800 WHP on stock bottom end endignes, it’s never a bad idea to put some better components in the block. The whole idea is that the parts are a bit more forgiving. (Obviously being indestructible isn’t a reality; but the bottom line is that the harsh environment associated with making more cylinder pressure is going to be there. The better components coupled with sound building practices will help ensure your best change of reliability and engine survival.
As for thd cosf, the entry level forged components aren’t as bad as one might think. Let me know if you would like a quote.
Very Respectfully,
Mike @ The Race Engine Shop
To C5 Z06 ECS Kit Novi 1500 Looking for 800 WHP + what’s next?
Quick Reply: C5 Z06 ECS Kit Novi 1500 Looking for 800 WHP + what’s next?
