Huron Twin Turbo build
Old 10-14-2018, 06:08 AM
  #61
CorvetteBrent
CorvetteBrent's Avatar
Originally Posted by FourG63 97GST
CCW 18x13, 345/35/18 mickey thompson street SS
Is your Corvette lowered, or is it still standard ride height? Just wondering whether, if I installed wider fenders like yours, my 355-30 with 19 '' rims would fit on a lowered car (mine was lowered by previous owner) or, if not, whether the 355 might fit on a standard ride height car.
Old 10-15-2018, 01:00 PM
  #62
FourG63 97GST
FourG63 97GST's Avatar
mines lowered, and the fender lip trimmed. i dont see 355s being a problem you nail the offset
CorvetteBrent (05-01-2019)
Old 12-17-2018, 09:11 PM
  #63
FourG63 97GST
started tuning finally, hard to abort the session short, as my balancer backed out, and lodged against the steering rack. so had to call it quits for the day
It have a 3psi springs in the gates. it's getting some boost creep I may have to address. as It was creeping to 7psi, I figure the 44mm gates should be sufficient with 3psi springs, But it's also recirculated into the downpies since I have the Gen 1 kit, the newer kits have the gates venting to atmosphere. I'm assuming that's why. I'll see how it does on the street, I really want to pull out as much power as a I can, so the car is very flexible. but power wise is it in the 660-670 range, which seems about standard
The blue line is with C02 on the gates, looks like it was about to party. but It hit the 10psi safety boost cut.
anyway, I'll fix it, it'll probably be street tuned from here. It's not dialed in, pretty rough draft at this point, but here's a lil something so the thread has some kind of resolution
miami993c297 (12-18-2018)
Old 12-18-2018, 10:21 AM
  #64
Turpid porpoise
Turpid porpoise's Avatar
Looks like its going to be very fun. Which balancer/bolt are you running?
Old 12-18-2018, 12:38 PM
  #65
FourG63 97GST
ARP and ATI balancer
Old 12-18-2018, 12:43 PM
  #66
mykream
mykream's Avatar
Gotta do longer pull ups on that breaker bar when tightening the balancer!!!..
Joking aside.. Is it pinned?
Old 12-20-2018, 10:47 PM
  #67
FourG63 97GST
it's not, I didn't think it was necessary being a turbo car. I assembled it on an engine stand. I'm assuming I just didn't torque it all the way and got distracted.
Old 12-29-2018, 01:34 PM
  #68
HardcoreABN
HardcoreABN's Avatar
You were having boost creep with CO2 on the back side of the gate or was that just with the 3lb springs in it?
Old 12-29-2018, 10:22 PM
  #69
C5 Kirkland
C5 Kirkland's Avatar
Looking good! Did a hose come off during the next to last run?
Old 12-31-2018, 08:20 PM
  #70
FourG63 97GST
just on spring, but could be the nature of the beast with how the plumbing is setup, with the C02 off, there's no pressure ontop of the gates. so the boost comes in lazy and centrifugal like as my log shows.
which can work in my favor, since my goal here is to work on the street and bring the power in later.
no, C02/boost controller was turned on, but ignition cut was at set at 10psi
twin383 (10-02-2021)
Old 03-03-2019, 05:26 PM
  #71
ITSWILL
Cruising
ITSWILL's Avatar
I'm working on making my own twin turbo setup and I am using the same hinson engine mounts and C6 oil pan. When I have the front tires at full rebound, hanging when jacked, I notice that the leaf is touching the oil pan. Was coil over required for this setup or was it just coincidence that you did this?
Old 03-04-2019, 05:35 AM
  #72
FourG63 97GST
Coincidence, I always had coilovers.
miami993c297 (03-05-2019)
Old 04-26-2019, 02:50 AM
  #73
FourG63 97GST
some street duty
build Auto coyote, outgunned but did what I can
GSXr1000
TT Camaro 1LE i help put together also. somewhat similar build, can where the 6.2 and TR6060 shines
The following 2 users liked this post by FourG63 97GST:
miami993c297 (04-26-2019), red03vette (04-27-2019)
Old 04-28-2019, 03:35 PM
  #74
venomws7
venomws7's Avatar
Great runs crank up the boooost man
What headlights are those?
Old 04-29-2019, 10:21 AM
  #75
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
Love the build!! Looks like I'm about to be doing a few cars with this kit.
Those are Radio Flyer headlights.
Old 04-29-2019, 10:51 AM
  #76
Turpid porpoise
That GSXR rider must have been quite disappointed lol.
FourG63 97GST (04-30-2019)
Old 04-29-2019, 12:43 PM
  #77
mykream
mykream's Avatar
It is the best thing in the world when you make one biker realize that a car can whoop on a bike
To Huron Twin Turbo build
Old 04-30-2019, 01:08 AM
  #78
FourG63 97GST
these are the Gen1 radioflyers
not ready to add power yet, i have the power coming in real lazy currently to make the car work on 18s. doing couple tweaks to the suspension and alignment, then see how much power I can bring in earlier.
I feel I can make it faster with the power it has now, I enjoy trying to make it work more than anything else, it's basically an adult science project for me
Old 05-03-2019, 02:37 PM
  #79
Vettelover1990
Vettelover1990's Avatar
Sick papito. Love seeing the blossom.
FourG63 97GST (05-29-2019)
Old 07-24-2020, 04:20 PM
  #80
niterydr
niterydr's Avatar
Updates? Great build, looks like you're having fun!
Quick Reply: Huron Twin Turbo build
