Proper crankcase evacuation and oil separation
Former Vendor
From Turbonetics on properly addressing crankcase pressure and effective air/oil separation:
BIG boost:
What it helps prevent:
Braided hose AN fitting option normally $100 plus option, NO EXTRA CHARGE for Corvette Forum members. When checking out, put "Corvette Forum" in the comments box.
And what our design traps:
Spun in a centrifuge and analysed we remove 70% water and acids (Sulfuric acid most common), 23% raw fuel, and 7% oil saturated with abrasive particulate matter (soot, ash, carbon).
The most effective air/oil separation crankcase evacuation system on the market under $500. Traps approximately 95% of the compounds you do not want ingested as part of the intake air charge while providing full time evacuation not allowing pressure to build to begin with. More power, less knock retard or detonation, longer engine life as engine oil remains cleaner as we remove most of the damaging compounds entering as blow-by before they can settle and mix with the oil.
www.RXCatchcans.com
BIG boost:
www.RXCatchcans.com
I just installed one of these, but instead of running the clean side separator to the blower air filter I stuck a breather filter directly on the CSS. My reasoning being that if it were run to the filter (which is mounted directly on the blower) it might see a vacuum. What do you think of this? Should the CSS have a check valve to only allow air in to the crankcase, thus maintaining the "closed system"/ "emissions legal" design?
May I ask why the passenger side valve cover pcv was closed off with a rubber nipple? I looped the driver side and passenger side valve covers together and ran my clean side separator to the airfilter on my procharged C5Z.
Former Vendor
Running Guns & Moonshine
Is that the CoSpeed can system there?
So I am getting Blow by. the catch can setup is doing its job. But this morning while going to work my dipstick decided it didn't want to stay on the tube so it came off (its not real secure anyway and probably needs a new oring). I assume it was a small 3rd gear down shift I did from 6th gear. how do I fix this from happening? I'm assuming its seeing crank case pressure.
