AA manual tensioner bolt?
Running Guns & Moonshine
Calling it a night.
I use zip-lock baggies for all my projects to stay organized and to keep from losing pieces. Somehow, I am missing the bolt and washer for my older AA procharger manual tensioner and it is making my brain itch!
Is it just a threaded bolt with a washer under the head, or something special? I don't recall by sight. And I don't recall if it had a sleeve to ride inside the bracket or not.
I know it is a 3/8" bolt, 1.5" length, nc16 thread, likely stage 8. Is that all I need?
Just bolt and washers. The bolt that you put your wrench on to tighten it is reverse thread so it doesnt come out when youre yanking on it. Again I dont know if our setup is the same but ill try and help lol.
I never thought to check for reverse threading. I'll be back to the car Tuesday night to take a look and see if I can find what I need. Thanks for commenting on reverse! I had only looked at the bolt going into the tensioner through the bracket.
Edit: In case anyone runs a search in the future and needs an answer... the bolt is normal thread and a commonly available stage 8 piece. As fate would have it, once I began reinstalling the blower tonight I did find the other bolt... right where I left it... in the mount for the catch can to the back of the bracket. Doh! Side note - the new RPM belt perhaps in conjunction with the new auto tensioner is REALLY tight. The washer on the sliding bolt for the manual tensioner is about 1" or maybe 1.5" in diameter. I could see on the back of the bracket that the manual tensioner is now one full "washer's width" to the outside.
