Tall valve cover that fit Jesel Shaft mount...Mine doesnt (Proform)... - CorvetteForum - Chevrolet Corvette Forum Discussion
Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Reload this Page >
Old 06-16-2018, 05:03 PM
always faster
CF Senior Member
always faster's Avatar
Default Tall valve cover that fit Jesel Shaft mount...Mine doesnt (Proform)...
Got a darton sleeved ls2 427 ci with some ETP Ls7 heads.
Using Jesel mohawk shaft mount.
I tried to make my Proform tall valve cover fit but they wont.The cover sit on the top of the rockers...
The bolt holes dont line up by something like 1/4 " ...
Even if i would like to make some grinding\clearance i would end up grinding the gasket groove...
What are you running to clear those ???
always faster is offline
Old 06-16-2018, 08:53 PM
douniasg
CF Senior Member
My proform fit with my trickflow 245. I have Proform 141-262 Valve Cover with jesel shaft mount.
douniasg is offline
Old 06-16-2018, 08:59 PM
douniasg
CF Senior Member
douniasg is offline
Old 06-17-2018, 08:42 PM
stevieturbo
CF Senior Member
stevieturbo's Avatar
Strangely....
Up until my TFS head blew apart, I was using Proform which fitted just fine.
I've recently just refitted some old Edelbrock heads I had as it was cheapest option to get going again and the fixing holes did not align with their hex stud adapters under the cover. In my case the hole was maybe 4mm or so off alignment with the hole being too high.
Whilst a little crude I simply loosened the hex adapter inside to allow a little movement on it and I was able to get the bolts in like this. Not a perfect fix, but I didnt fancy drilling the covers which would probably see more chance of oil leaks around that area.
So the problem isnt so much the covers...as the heads in my case.
Probably if you were to revert to a long bolt with a spacer sleeve inside the cover it might allow a little more movement to line up. The actual base where the hex adapters bolt to on the head must be at a slightly incorrect angle
stevieturbo is offline
Old 06-18-2018, 11:28 AM
always faster
CF Senior Member
My Proform did clear my other Jesel shaft mount setup on my 799 heads but they aren't on my ETP...
always faster
CF Senior Member
Originally Posted by stevieturbo View Post
Strangely....
Well my english is not perfect but I'll try to be clear.
Even if I could play with the mounting it wouldn't fit since the cover are sitting on the rocker...
Not on the adjuster but on the back side of the rocker , the cover can't even slide down.
A lot of time you grind a small area in the head to clear the rocker rotation and that's fine .
I was thinking about making the same kind of grinding inside the cover to also clear the rocker .
But I would need to take way too much material.
Will try to take some pics tomorrow
​​​​​​​Looking at some Katech since they clear everything .
Old 06-18-2018, 11:50 AM
stevieturbo
CF Senior Member
Ahh, so your cover actually fouls the rockers ?
On both the heads I used they clear the rockers ok ( both cathedrals ), just that with the Edelbrocks the cover bolt holes would not align correctly.
Old 06-19-2018, 11:26 AM
always faster
CF Senior Member
Here are the pics, you can see that they dont fit.
You can also see that the gasket groove design could have been made more outward , it would have reduce the inside thickness and fit.
You can also see that the gasket groove is not even on the head surface.1/2 of it is but the other half not.
I cant move the cover down since it sitting on the rocker...
Will order some Katech and sell those
Old 06-19-2018, 02:39 PM
stevieturbo
CF Senior Member
Now that I think about it, I might have had to clearance the covers a little for mine. Cant recall exactly. And your rockers are a lot chunkier than the Jesels.
And looking at photos, it looks like the gasket flange on your head is thinner than on my TFS225 and Edelbrock, the Edelbrocks have a pretty wide flange.
Old 06-19-2018, 09:02 PM
douniasg
CF Senior Member
Maybe the offset rocker is causing a problem. I would sell the proform before modifying them.
douniasg is offline
Old 06-20-2018, 12:18 PM
always faster
CF Senior Member
And I think that you're right.Not all the rocker seems to touch the cover...
Old 06-21-2018, 12:42 PM
always faster
CF Senior Member
Katech Slotted with 2 blank insert have been ordered.
Will do my own engraving with my Mazak CNC .
Old 06-23-2018, 05:22 PM
always faster
CF Senior Member
Well i rceived the Katech and add some additionnal clearance on the notch that was already pre machined on the cover.
Now it seems to fit but ...
The gasket doesnt fully sit on the top head surface ...Maybe 50%.
You can see from the pics that it fit good on the 3 dip but not on the head ...
The only thing i could think by looking at my heads its that if you look carefully enough you can see that the the botton of the head isnt fully straight.You can see that there is 3 bump and 2 of them are exactly where the two valve cover support tab sit inside the head...It make the cover fit higher.
To solve that is to grind the two lower tab on the valve cover a bit but im worried that it will create some rocker rubbing and i dont have anymore space to grind...
Old 06-23-2018, 06:07 PM
stevieturbo
CF Senior Member
Although mine are cathedrals...
Compared to the TFS, the flange around your head does look a little thinner.
Compared to my Edelbrocks...the flange on both TFS is a lot thinner
Have any covers you had fitted around that gasket area correctly ? If you remove the rockers, will a stock cover even fit ?
Old 06-23-2018, 07:16 PM
always faster
CF Senior Member
Well i tried to shave 1/16 of valve cover the supportig tab, gasket seems a bit better ,not perfect but better but now i lost clearance and the rocker are rubbing...
Notch the cover even more and still rub not a lot but,...it even think that it rub the valve cover gasket...
Now im stuck and dont know what to do...
Old 06-23-2018, 07:18 PM
always faster
CF Senior Member
Dont know, Proform doesnt and now Katech doesnt...
Even without the rubbing issue, the cover seems way to far upward...
Old 06-23-2018, 10:34 PM
stevieturbo
CF Senior Member
IMO remove the rockers and try some stock covers.
Just in case something is fucked up with the heads themselves. In which case you'll just have to adapt some covers as a head swap is hardly likely. Or maybe some stock covers with spacers ?
Old 06-26-2018, 11:32 AM
always faster
CF Senior Member
Did some testing and the stock VC seems to have the same issue.
I ll take other pics and will make some other testing...
Old 06-26-2018, 03:37 PM
stevieturbo
CF Senior Member
That's a very bad sign...and points in one direction !!
Manufacturer defect with the heads.
Old 07-04-2018, 09:30 AM
always faster
CF Senior Member
Well when you cant modify the VC to work ...just mod the heads.
Ill take my tig and weld some bead to create a thicker flange with some support underneath it and then will put the head in the cnc to have it perfectly straight.
Quick idea in red.
Done deal
Quick Reply: Tall valve cover that fit Jesel Shaft mount...Mine doesnt (Proform)...
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
