N2O how big are you running on the stock fuel system
How much juice are you running on the stock fuel system? And how much timing did you take out?
Re: N2O how big are you running on the stock fuel system (ICULUKN-C5)
On stock fuel system I did 75dry+150wet= 225 hp shot maximum on top of my heads/cam.
For more (tried up to 300 shot) I needed an other fuel pump.
I took out 5 degrees of timing.
Michael
[Modified by Austrian Vette, 8:13 PM 10/20/2002]
Michael
Stock fuel pump, stock timing... 127rwhp gain.
But I'm not running nearly as fast as either of you guys. :)
Re: N2O how big are you running on the stock fuel system (newberd)
So far i pulled 2 degrees @ 2400 RPM & 6 degrees at 5000
Still waiting for my cage so I can mount my bottles.
