Fuel injector recommendation for NX Nitrous 100 shot..
1 Post
I'm definately going with a wet 100 shot with my H/C setup..Will the 26# stock injectors do the job or should I think about SVO 30# injectors :rolleyes:
Re: Fuel injector recommendation for NX Nitrous 100 shot.. (vstella)
If it's a wet shot, you really don't need to worry about your injectors. Unless you tuned it wrong (what I mean is that you set your fuel jetting too lean and are relying on your motor running rich NA to offset that). Injectors should matter only on a dry kit.
But with H/C, I would just go 30# injectors anyway.
[Modified by akw408, 9:10 PM 10/21/2002]
I was spraying 150 hp with stock 26lb injectors, never had problem, picked up 8 tenths in the 1/4. Even with the H/C you should still be fine. With a wet system, you do not rely on the injectors to supply more fuel, that is the job of the fuel solenoid. As long as your car is tuned, and running fine now, with your H/C combo, I wouldn't worry about changing them. :cheers:
Re: Fuel injector recommendation for NX Nitrous 100 shot.. (kwik8racr)
Post what you decide to do because I too am going to the NX 100 shot. Will install this fall. Going to do the 2 fuel noids and the 2 NX noids for added safety. Also, my add a progressive controler.
Re: Fuel injector recommendation for NX Nitrous 100 shot.. (DUKE)
wouldnt worry about your injectors.. wet shot adds its own fuel. If you were running dry I would say upgrade.
You don´t need to step up injectors on a wet setup, but
I did the 30 SVO injectors as on the NA runs with big cam I needed the bigger injectors.
Michael
Michael
Former Vendor
:cheers:
-Tuan
Re: Fuel injector recommendation for NX Nitrous 100 shot.. (Tuan Le)
Tuan,
Are you going to try it? Cool.. So am I. I am rewiring my set up now. I got my 6 point cage in. Should have some info next week. I still have to clean my solenoids.
Former Vendor
Re: Fuel injector recommendation for NX Nitrous 100 shot.. (ICULUKN-C5)
Tuan,
Hopefully everything will work out as planned. :cheers:
