383 with D1sc dyno results
Old 07-16-2018, 01:56 PM
z0stix
z0stix's Avatar
Default 383 with D1sc dyno results
forged 383 bottom end(eagle crank/rods diamond pistons)
stock 243 heads with ls9 head gaskets, roughly 10.7 compression
Jam Cam
speed engineering 1 7/8 headers
A&A secondary drive
D1 procharger 14psi
dual nozzle meth
SD tune (cobalt map sensor)
107* south Texas weather
was hoping for 800hp but only put down about 780hp but the torque was right there as well at 750ft/lbs, before on the stock bottom end torque was always way behind....I'm sure in cooler weather it will make for horses
CorvetteBrent (09-07-2018)
Old 07-16-2018, 03:01 PM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
Old 07-16-2018, 05:22 PM
silver408z
silver408z's Avatar
Nice numbers. The D1 is great head unit. Like you said in cool weather you might make the 800. Also what filter are you running in front of the head unit? Have you tried a velocity stack?
Old 07-16-2018, 05:59 PM
hatewhatownsyou
hatewhatownsyou's Avatar
This makes me regret not going with a 4” stroke crank
Old 07-16-2018, 06:19 PM
z0stix
z0stix's Avatar
I'm running an old a&a procharger kit with 4" piping, I just upgraded to their latest bracket and tensioner and secondary drive
not my pic, but same piping and intercooler
Old 07-18-2018, 05:48 AM
AtlasInTheGym
AtlasInTheGym's Avatar
Looks good man! Im running something very similar. 383 (-7cc pistons) Ti-trim A&A kit with secondary drive, hitting about 13psi on 9.0 compression. made 737rwhp. Looks like that extra compression is helping you out.
Old 07-20-2018, 01:11 AM
z0stix
z0stix's Avatar
yea I think so, and timing is set to about 19/20....the dual nozzle meth helps, ...for fuel I'm just running 60lbs injectors with walbro 255 pump with a KB boost a pump
Old 07-20-2018, 04:23 PM
tbrent
tbrent's Avatar
2018 C5 of Year Winner
Old 07-20-2018, 11:02 PM
EgoKlr
EgoKlr's Avatar
I’m not familiar with the procharger pulleys but can you drop down just a lil in size and squeeze out that 800 rwhp with more boost?
Old 07-21-2018, 01:14 AM
z0stix
z0stix's Avatar
I'm sure I'll be at 800hp when temps get cooler and away from triple digits....already have a 3.4 pulley with 10% over drive balancer
Old 07-21-2018, 01:45 AM
neutron82
neutron82's Avatar
how high did they rev to on the dyno?... might just need a little more rpm to hit 800 but it should still haul either way
Old 08-21-2018, 11:43 PM
69GTO96Z
69GTO96Z's Avatar
Love it! I am making a tad more HP with a YSi on a forged 346, but you blow my torque away. I have a 383 in my SS, I should swap motors between the cars!
Old 08-27-2018, 10:25 AM
juice12
juice12's Avatar
I make 837 745 and it's about too much on the street. Mine has way more in it, thats with e85 and 15 degrees of timing. Ls2 forged bottom
The following 2 users liked this post by juice12:
CorvetteBrent (09-07-2018), gsx1300rrr (09-01-2018)
Old 08-31-2018, 02:22 PM
_zebra
_zebra's Avatar
haha... reminds me of a MotorTrend (i think) article i was reading the other day about the '19 ZR1 vs the Z06 & how, rather than just revving a little higher for the bigger HP number, they actually just make more torque all over.
not slamming OP's car or nothing, though... that's good stuff & the cooler air will help us all. hopefully it cools off by the time Bret gets done with mine & it's ready to dyno.
Old 09-03-2018, 11:16 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
Doesn’t the 4” stroke on ls1/6 blocks have the bottom of the piston skirt extending below the liner and rocks/slams back into line ready or not when the crankshaft is headed up?
Isnt it a no-no doing a stroker crank (for longevity) unless you have a deep skirted ls7 style block?
Old 09-04-2018, 11:20 AM
silver408z
silver408z's Avatar
Most builders say 4" is about as far as you want to go for all the concerns you mentioned. Even with a 4" stroke you still have some problems like you mentioned.
To 383 with D1sc dyno results
Quick Reply: 383 with D1sc dyno results
