Need advice on decent balancer to use with A&A supercharger
Received 1,248 Likes
St. Jude Donor '21
Preferably from those that have had a centrifugal SC kit for a while, please opine on balancers that worked and ones that failed.
I will spend what I need to in order to have a harmonic balancer that will hold up to the stress of driving a supercharger, but do not want to needlessly overspend just to have the BEST.
Thank you!
Thank you!
Supporting Vendor
Thank you!
Thank you!
Naturally Vain (02-22-2019)
Received 1,261 Likes
innovators west is a good balancer, pricey but worth it... I've had one on my car for a few years and no problems, I agree with Bret and you might as well get an overdrive and 8 or 10 ribs as well if you think you will ever upgrade the belt drive that way you don't have to buy the balancer again
Supporting Vendor
Supporting Vendor
Blue ***** (that's my boy) was correct, summit has belt on front so 2 ribs towards the engine are not used. Of course this only matters if you are going to run all out and need an 8 rib belt. I'm at 12 #'s and seem fine with a 6 rib. So it depends on what you really need.
Few hundred miles on a 10% od innovators west with the new a&a flip drive setup that uses two belts. No issue with the balancer so far. It looked really pretty nib too, was a shame its hidden after install.
I had a brand new ACdelco balancer installed. Running a 3.6 pulley at 11psi for over 5k miles with no problems. The shop that did my install hasn't had any problems with basic supercharger builds.
I using an ATI, Stock size. Wish I would havew planned ahead and did an 8 rib inovators west but my set up is working great(6 rib 3.6 pulley)with no slipping. Guess we'll see what happens with the 3.4 this winter.
St. Jude Donor '21
Gents, thanks for all of the feedback. For what I am building, I went with a Powerbond stock replacement. I asked Andy about it and he thought it should be fine for a relatively mild build such as mine. I do not plan on going much higher than 550 whp as IMO this is the level that will really start increasing the chances of a piston/rod failure. If it fails, I will be sure to post it here.
St. Jude Donor '21
If I do that, it will be forged short block (I do not want to risk total destruction of the block and crank) and upgraded clutch and drivetrain parts - so I could upgrade at that point. Time will tell though - you are correct that we always seem to want more!
Great to hear, this is the pulley I went with as well. After watching a few of your videos, I will have a pretty close set up to yours. Stock exhaust manifolds, and cats, 3.6 pulley, and a cat back. But, I went with a Dewitts cut down radiator and matching spal fans to try and avoid lowering the radiator support. My driveway is already unfriendly enough to low cars.
