Nitrous Wiring
Love seeing other setups whether simple or complex so share your ideas/work.
Relocating the battery to the rear passenger cubby hole and the panel pictured below will sit as such. Will have a single terminal strip along the firewall where the battery sat to run my solenoid wiring too. I am still wiring up the panel board for the rear and making one main harness to run through the car. I have to say, I am a fan of the leash electronics boards. Makes wiring the system very easy and extremely clean.
I have been using a LOT of Littlefuse products lately. Really hard to beat their blank fuse / relay centers.
a lot more room to bundle the wires and pass through somewhere.
The other pic is the loom I have been using that I bought from Racetronix. Really clean durable material. Terminated both ends with heat shrink which makes it look even cleaner when said and done. It is only about 1-2 dollars per 10 ft of it and
I bought the 1/4 and 3/8 loom.
