6.0 block max overbore!
Hi
I wanna know whether a 6.0 iron block with .040 over holds up fine with about 16lbs of boost to make 1000 flywheel horsepower or not?
By the way, it will be an offroad race truck.
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Yep. It should. But there are always exceptions.
I’m filling mine with HardBlock to the water holes and plan to run 30lbs on a 4.030 bore.
Why 4.040? No shelf pistons available in that size. Most are 4.005/4.030/4.060 type stuff.
Thanks for your response
That 40 over is for clearing the cracks.
I don't have problem with pistons, maybe a set of forged sbc ones with some customizations!
I've seen guys running stock block in same hp range for years with turbos but with .030 over. But everybody says it's max overboring for FI engine.
I was curious to know if that 0.005! less wall thickness makes problem or no! 😅
Supporting Vendor
One block might be okay and another not so much. You can find a shop with a sonic tester to verify thicknesses on all of the cylinders. Cap'n Huff mentioned, filling the block with a bit of concrete and should help stabilize the cylinders even more and increase your guarantee of things staying together. I can't say that I would recommend running SBC pistons in an LS engine. There are far too many differences to even bother. I can have you a set of custom pistons made if you're interested. I would recommend doing that with a nice set of rings along with a set of tool steel wrist pins so that they hold up to the abuse better. Let me know if I can help.
Bret
Bret
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Thanks bret for sharing your knowledge
How much wall thickness do you recommend for less than 20lbs of boost and not much of compression ratio on that block?
And what about putting new dry sleeves in it? Would it increase the strength?
For the pistons, as sbc pistons share same dimensions with ls ones (I think the main difference is just in ring widths) I thought they can be used and actually I've seen some ls motors with them, but what am I missing?
Supporting Vendor
AMP Racing
If you’re already talking about clearing out cracks for an overbore, take Bret’s advice and get a “new” seasoned block.
Best of success with your project.
