What kind of fuel pump should I get for twin turbo C5Z?
I have around 700rwhp and the UPP setup including their fuel system. Im losing fuel pressure during normal driving from 58 now down to 52-54. I figured its time to replace the stock in tank pump and filter since its from 2001. Any ideas what pump I should get to replace stock one?
Lingenfelter and Racetronix make drop in pumps but you can get creative and fit a 450 in there for more headroom.
I run twin 340's with the racetronix harness and its worked great. I'm well north of your power level. First pump runs all the time, the second one kicks on via a Hobbs switch once boost is seen.
- Travis
- Travis
I would think you run a return style reg with that- to which tank does the return run?
- Travis
StatmanRN (08-31-2018)
Are you still on the OEM returnless fuel system or do you have a boost reference regulator installed?
