02z getting A&A kit installed, need some advice
Hey guys, ordered v3 si kit from Andy this weekend and planning to install at home whenever it comes in. The car currently has 224/230 114 comp cam with only axle back borla. I wanted to get some opinions on pulley size. Should I stick with the 3.8 or go for a little more boost with the 3.6. Will be leaving the stock headers on it with the h-pipe. Car is my daily and dont want it to be too loud. Stock clutch has not been acting up so will ride it until it gives, then replace with better.
Also, for tires, would you guys rec going with something wider than the 295 or get a stickier compound on the stock speedlines? Nitto, MT, toyo??
Any other advice on the install? I guess hood and front bumper off completely?
Thanks in advance!
Thanks in advance!
albodent (08-22-2018)
I'd leave the 3.8 if you have stock exhaust. You are leaving a lot of restriction there which isnt great for the engine. Definetly forcing more air in there than the exhaust can get rid of.
What are you goals with the car, regarding tire usage.
You will need a clutch. No way around it. I wouldn't even try it without.
Thanks for the replies, fellas! The car is my daily and I am just looking to make some more power without sacrificing too much. Very short ride to work and no clutch dumping or power shifting. I want to be at mid to high 500 to the wheels, its useful and fun. Anything beyond that seems like a struggle to put down and maintain.
For tires, I have super sports on my blown viper and not too big a fan. Car still skates around, regardless if warmed up or not. Might have to get something stickier.
The clutch has not given me any issues so far. Some Sebring days and local drag strip. Once it gives, I will pick up another. Maybe c6z clutch to swap out at home on the lift.
I may just start off with the larger pulley and then move down once the bug bites again. Hope this keeps me smiling for a while. I am sure I will have more questions as I run into issues with install. Seems straight forward so far, wanted to pick up some gems while here before I start taking it apart.
I have not used them, but Toyo R888 may be something to look into.
I have M/T SS on the back. They hold 700+
Two very different tires used for different reasons.
