Which Cam to get pre-A&A Supercharger on a 2004 C5 Z06?
Old 09-06-2018, 09:02 PM
Naturally Vain
Naturally Vain's Avatar
Default Which Cam to get pre-A&A Supercharger on a 2004 C5 Z06?
Hey guys, I am eventually going to get an A&A Supercharger kit on my C5 Z06, but want some added power in the mean time with a Cam. Which Cam would work best for the future Supercharger Mod and what power gains can I expect from just the cam? Are there specific cams I should look for given the future mod or will any work? Recommendations?
I have Headers, X Pipe, No Cats, Corsa Extreme and dynoed at 382/370 so far.
Let me Know, open to all suggestions! What have you guys got?
CorvetteBrent (09-07-2018)
Old 09-06-2018, 11:37 PM
silver408z
silver408z's Avatar
You can always check the various sponsors but the jam cam seems to work and be popular. Blownbluezo6 is a great source parts and answered questions.
The following 2 users liked this post by silver408z:
CorvetteBrent (09-07-2018), Naturally Vain (09-07-2018)
Old 09-07-2018, 12:07 AM
Naturally Vain
Is this Arun's Jam Cam from the youtube videos?
Old 09-07-2018, 12:18 AM
silver408z
silver408z's Avatar
Not sure who all developed but I have only seen people talking about 1 of them.
Old 09-07-2018, 12:59 AM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
114lsa is about as tight as I’d go. Sounds cammed but doesn’t bleed off too much boost.
Get one with more exhaust overlap to help clear the cylinders. Like a 224/228 or 232/236 etc.
Plenty of off the shelf cams to choose from. Comp 224/228 .588 .588 114lsa would sound cammed, run great N/A (almost stock manners) and also boosted.
115lsa (or higher) sounds more stock unless you have a lot of duration which has low rpm cam surge (bucking/surging in parking lots idling around) issues and sloppy low/mid rpm manners in favor of high rpm rage.
Old 09-07-2018, 02:44 AM
NSFW
NSFW's Avatar
Overlap tells you how lumpy the idle will be, but LSA really doesn't - unless you do some math that includes the durations. As the lobes get bigger, you get more overlap for a given LSA.
224/228 at 114 would have -2 degrees of overlap - no overlap at all, and 2 degrees would pass in between the closing of the exhaust valve and the opening of the intake valve.
232/236 at 114 would have 6 degrees of overlap. To get the same overlap as 224/228@114, you'd need an LSA of 118.
To get 6 degrees of overlap with a 224/228, you'd need an LSA of 110.
Old 09-07-2018, 09:47 PM
Naturally Vain
I have been resorting to looking up each cam on Youtube and listening to the sound. Sounds juvenile I know, but thats the only way I can tell. So LSA really won't be an indicator of sound? Any base line way to tell how it would sound?
Also would something like a BTR Stage 4 cam or Torquer 4 or Vengeance Vindicator or VrX3 be out of the question if I plan to supercharge it? Ideally I want a nice deep sound with some cam noise but I want to avoid the cams that sound like the car is about to shut off if that makes sense.
Old 09-08-2018, 12:09 AM
Naturally Vain
Adding this post I found in my thread for educational purposes!
10-04-2011, 04:43 AM #2
SCM_CrashCF Senior Member
Member Since: Jul 2009Location: Los Angeles CaliforniaPosts: 9,526Thanks: 0Thanked 3 Times in 3 Posts
The LSA on that cam is really low for forced induction. A good rule of thumb is not to go below 115 LSA because with forced induction you'll end up blowing all the forced air right out the exhaust when the LSA is that low. For an N/A setup, a lower LSA will give you more power higher in the RPMs because the exhaust gasses help suck air from the intake on their exit. But forced induction pushes the air into the chamber. Since the lower LSA means the exhaust valve will be open longer while the intake valve is open, you'd be pushing some of that air right back out the exhaust port until the exhaust valve shuts.
So the short answer is, you might want to find a cam with a higher LSA.
Old 09-08-2018, 12:31 AM
Water_Walker
Water_Walker's Avatar
Custom for your particular situation. Blownbluezo6 is the man.
Old 09-08-2018, 05:38 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
I agree get this cam here a lot of vendors in here has copied the spec of Arun cam due to the horse power it has done in both N/A & blower set up.
This cam you can also live with as a street cam also.. Robert
Old 09-09-2018, 12:53 AM
Naturally Vain
Having trouble finding the Jam Cam from Arun. Anyone got any links?
Old 09-09-2018, 01:21 AM
stangin4lyfe
stangin4lyfe's Avatar
Not sure if this cam is the same specs or not...
https://m.briantooleyracing.com/item/3133313732
Old 09-09-2018, 10:18 AM
Smoken1
Support Corvetteforum!
Smoken1's Avatar
BTR Jam Cam specs, I just put this same cam in
File Type: pdf
NSFW (09-09-2018)
Old 09-09-2018, 02:36 PM
NSFW
NSFW's Avatar
That says:
230 / 242, 115 + 4
.608 / .615
46 IVC, 6 degrees overlap
Anyone know if this cam will fit an otherwise-stock LS1 / LS6 without PTV clearance issues?
Old 09-09-2018, 02:55 PM
Naturally Vain
How much did you gain just from the cam alone? Thanks for all the info!
Old 09-09-2018, 05:08 PM
NSFW
NSFW's Avatar
It's my understanding that overlap is the biggest factor in idle sound, and low RPM driveability as well. LSA is slightly related to overlap, but if you have two cams with the same LSA and different size lobes, the one with the larger lobes will have more overlap, so LSA by itself isn't a very good indicator.
Cam Motion has a really nice app for Windows that lets you enter the durations and LSA, and it will calculate the open/close angles and the overlap. I've been using it a lot as I take notes about what sorts of results people report from their cams: http://www.cammotion.com/cam-timer
Also, if you have two engines with the same overlap but different displacement, the one with more displacement will have a smoother idle. Displacement sort of compensates for overlap in that way. So if you're comparing idle performance, its best to focus on results from engines with the same displacement as your own.
Naturally Vain (09-09-2018)
Old 09-09-2018, 08:19 PM
ss4luck
ss4luck's Avatar
I ran an A&A stage 2 blower cam with my V3Si and absolutely loved it. Strong power band, great drivability and solid chop
Old 09-09-2018, 10:20 PM
Naturally Vain
Is that the same cam on the BTR website listed as A&A Supercharged Camshaft, 32030163
https://www.briantooleyracing.com/a-...-camshaft.html
Old 09-25-2018, 10:27 PM
robert miller
Yes that is it Arun knows Brain good & that is the same cam. I getting this same cam now for my C7 & a ton of other parts for the car. Robert
To Which Cam to get pre-A&A Supercharger on a 2004 C5 Z06?
Quick Reply: Which Cam to get pre-A&A Supercharger on a 2004 C5 Z06?
