C5z bad motor
C5z bad motor
Hey guys just picked up a nice 01 c5z with a hole in the side of the block. Looking for a short block replacement that will be able to handle a ysi. Let me know what you recommend! Thanks
Google tons of info out there. But heard the ls3 has been kicking some but. Check out c5 section. Stock ls3 at 900 whp
[QUOTE=rcognati;1598372657]
I like a forged crank iron block with well ported tfs heads
I happen to have one if you need it, or a forged ls6 engine out of my twin turbo car
either will handle 900 + without issue
the forged bottom end ls6 is putting down 800 at the tire at 18 psi through an auto
[/QUOTI like a forged crank iron block with well ported tfs heads
We have some great deals on Black Friday that could work for you as well as tons of in stock options. Give us a call. 972-853-2450.
Thank you for the recommendation Under-Pressure!!!
