Turbo Experts: Please chime in!
Old 11-23-2018, 02:43 PM
s2kpunisher
s2kpunisher's Avatar
Default Turbo Experts: Please chime in!
About a month ago I picked up a Frankenstein of a project, any opinions/suggestions are welcomed (good/bad). Previous owner daily drove for 4 years/40K miles on this setup and claims running lean is safer even though less efficient/less power with the Speed Density tune. My goal for this car is to keep it a canyon carver (1-2 HPDE a year) but I'm confused if I should keep it as is or get it re-tuned for more power (how much/safe?). My Corvette specialty shop already did a leak-down test/compression test, inspected the motor/turbo/tranny/diff are in tip-top shape.
1999 C5 FRC setup for daily driving/reliability, made 560whp on 12lbs and 460whp on 6lbs on 91 octane. Runs rich, AFR 14 in idle and 10 or less at WOT based on gauge:
LS6 swapped (forged/balanced)
Turbocharged (Turbonetics single T76)
Front mount intercooler
Tial waste gate and BOV
Meth injection( not hooked up)
Boost controller(in center console)
Dynojet wideband commander
S.D. tuned
60lb fuel injectors
Walbro 450 fuel pump
Compstar rods
Mahle pistons
ARP bolts
Comp 918 valve springs
Comp Gardened push rods
317 heads
Z06 cam
Old 11-23-2018, 03:02 PM
_zebra
_zebra's Avatar
sounds like it's running rich, which is the safer option (to a point).
with those heads lowering compression (assuming 71cc chambers), you're good for more boost, and with a forged motor, there shouldn't be any worries turning it up - folks safely make more than that all the time on stock long blocks.
CorvetteBrent (12-08-2018)
Old 11-23-2018, 03:16 PM
s2kpunisher
Where can I get it tuned for more boost and how much more you think? Should I stick with Speed Density? I can't even find a website/phone number for them I guess they are gone?
Old 11-23-2018, 05:10 PM
_zebra
_zebra's Avatar
there're likely a number of reputable LS tuners in SoCal if you're wanting somebody local. others on here can also datalog & email you tune files (requires specific equipment, but any one of them can talk you through that).
speed density tuning ain't a company; it's a way of tuning that runs based off of manifold pressure rather than also using the mass air flow sensor.
Old 11-23-2018, 06:52 PM
s2kpunisher
Appreciate the input.
Anyone here know of an experienced tuner in SoCal?
Old 11-23-2018, 07:02 PM
aaronc7
aaronc7's Avatar
If you're going to retune and want some more power... highly recommend you get the meth kit up and running or look into converting to E85. 91 octane is already the big limiting factor in your setup. E85 route will probably require all new fuel system though, so maybe the methanol route is more appealing in your case.
Old 11-23-2018, 07:03 PM
Pb82 Ronin
Pb82 Ronin's Avatar
At 10> AFR you're washing your cylinders down with raw fuel. Absolutely CRAP for power and terrible for your engine. You have probably 60-70 rw available in just the AFR in the tune. I ran turbo's AND nitrous on 11.8-12.0 AFR (on pump gas) with the right plugs and tune. And why speed density? That to me sounds like the tuner didn't know how to tune a mass air system and went with speed density for comfort because he didn't want to hurt a turbo corvette. Do NOT let than human touch your car again. Find a real tuner.
(EDIT: Meth is a waste of money)
Old 11-27-2018, 12:35 PM
nickalltogether
nickalltogether's Avatar
At that power level he's maxxing out the MAF. So you're either adding fuel by cranking the PE table up or skewing other things incorrectly. I'm not defending the tuner, but saying they went to speed density out of comfort is a pretty big leap... especially since most people would consider mass air to be easier to tune "quick and dirty".
Old 11-27-2018, 02:47 PM
Pb82 Ronin
Pb82 Ronin's Avatar
2 ways around this. Get a better MAF, or get an extender like a MAFia. Mass air is ALWAYS friendlier than speed density when it comes to efficiency and driveability.
Old 11-28-2018, 01:58 PM
Turpid porpoise
Turpid porpoise's Avatar
I've never had an issue with a speed density tune in regards to driveability or efficiency. The problem with this chassis lies in the PCM not the MAF itself. I believe the PCM will only read up to 511 grams/second and 12,000Hz(these figures may be off a little bit).
Old 11-28-2018, 02:09 PM
junk c5
junk c5's Avatar
Everyone around here prefers speed density and it’s considered an upgrade. My cars been converted to speed density for years and has great street manners as well as runs well at 18lbs.
For peace of mind, I would have a reputable tuner check out your tune . Being too fat can cause problems.
Old 11-28-2018, 06:38 PM
s2kpunisher
Here’s my number from my mechanic inspection:
Comp test:
140-8
150-7
150-6
150-5
148-4
145-3
147-2
140-1
Leakdown test:
10%-8
10%-7
9%-6
10%-5
11%-4
11%-3
10%-2
10%-1
Guys with Speed Density what are your AFR in WOT?
Old 11-29-2018, 06:00 AM
Rkreigh
Rkreigh's Avatar
Comp test:
140-8
150-7
150-6
150-5
148-4
145-3
147-2
140-1
Leakdown test:
10%-8
10%-7
9%-6
10%-5
11%-4
11%-3
10%-2
10%-1
for turbo applications I like around 11.5 afr I'd really recommend a bit more turbo and e85
that turbo m ight choke a v8 and spike up exh back pressure and it won't be in the efficiency range of the turbo
need to get more specs on that turbo but I'm not a fan of teeny weeny turbos on a v8
don't choke it
Old 11-29-2018, 09:16 AM
Pb82 Ronin
Pb82 Ronin's Avatar
Hope you don't ever see more than that 18 psi since you're on speed density. Things will go pop.
Old 11-29-2018, 09:19 AM
s2kpunisher
don't choke it
Previous owner lost receipts so no clue what turbo specs are. Do I have to pull the unit to see a spec on it somewhere?
I want to keep this turbo as is and if necessary just tune for 11.5AFR regardless of power. Is 6psi/12psi too much for this kit?
Forgot to mention it’s tune to boost 6psi from gears 1-2 and 3-6 are 12psi.
Old 11-29-2018, 09:44 AM
Turpid porpoise
How do you figure that? If the MAP can read higher and he has the fuel to compensate for the increased airflow he will be fine.
Old 11-29-2018, 09:46 AM
Turpid porpoise
Don't just shoot for a specific AFR, tune it to where the car is running safely and efficiently. Just pick a good tuner and let them work their magic.
To Turbo Experts: Please chime in!
Old 11-29-2018, 09:59 AM
s2kpunisher
don't choke it
Being that I won’t be changing the T76 turbonetics any time soon what psi should I run to avoid choke/spike back pressure?
Old 11-29-2018, 10:09 AM
junk c5
junk c5's Avatar
Ive got a 3 bar map and a very experienced tuner. I’ve seen him tune cars in excess of 30lbs. I’m very confident in my combo and tuner
Old 11-29-2018, 10:16 AM
junk c5
junk c5's Avatar
It would be ideal to install a device in the exhaust housing to measure back pressure just to know where you stand. I’d start around 8-10 lbs and see where everything is at. If your satisfied with your hp level at 10lbs, then tune for optimal drivability. An experienced tuner will point you in the right direction.
At bare minimum, the exhaust housing should have numbers indicating its size.
Quick Reply: Turbo Experts: Please chime in!
