C5 Z06 custom rear mount twin turbo build
#41
both the tiix and huron kits mount the turbos high enough to gravity drain and will feed between 700 to 1000 hp nicely
at that level you will tear things up in the drivetrain fast
I'd look at the huron, brand new they can be had for an affordable price, the turbos are NEW and bigger than the ttix kit
and the intake ducting and exh are routed better due to the tilted turbo
this kit comes with a 3" exh and down pipes which is extra with the ttix
3800 sounds like a "deal" until you find out you have an issue
are you doing the install yourself? You said you like work. Well to do this kit it's easier to drop the cradles and install
trust me, it's harder if you don't
as many have said, if your goals are bit more modest, and you don't mind "less work" a Novi will spank out just as much power, is more linear in delivery and much easier to install and cheaper
pick your poison don't forget to budget for the drivetrain upgrades or the power is pretty adept and putting your car back on the trailer
