Holly Hi Ram installed
Old 12-21-2018, 11:19 AM
douniasg
douniasg's Avatar
Default Holley Hi Ram installed
Decided to cut my hood for the holley hi ram. Here some pics. I think it looks Bad A$$!
Old 12-21-2018, 12:34 PM
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
Any pictures of the rest of the build? Twin turbos?
Old 12-21-2018, 01:00 PM
douniasg
douniasg's Avatar
Yes sir. It is slowly coming together.
Bruss (02-16-2022)
Old 12-21-2018, 01:25 PM
Turpid porpoise
Turpid porpoise's Avatar
Quite the unique lid you’ve got on there, I like it
Old 12-21-2018, 01:35 PM
douniasg
douniasg's Avatar
Car has a powerglide up front with a 9" irs in the rear. Hoping to run hi 7's low 8's when done.
Old 12-21-2018, 01:40 PM
douniasg
douniasg's Avatar
Thanks, I didn't like the throttle body sticking out and extra cuts in the hood. I had it fabricated.
simman22 (12-21-2018)
Old 12-21-2018, 02:24 PM
algZO6
algZO6's Avatar
you have to cut the well for the 9"?
Old 12-21-2018, 02:35 PM
douniasg
douniasg's Avatar
I don't think so. The diff sits further forward then the stock diff did. I cut it out so I can mount it easier also for fuel cell.
Old 12-21-2018, 05:00 PM
FourG63 97GST
FourG63 97GST's Avatar
well executed, this guy clearly likes to party
Old 12-21-2018, 06:32 PM
douniasg
douniasg's Avatar
Thanks , I really like your setup. It is really clean. Maybe will meet at Pbir someday. I recently moved to lake worth.
Old 12-21-2018, 07:42 PM
C5 Kirkland
C5 Kirkland's Avatar
Originally Posted by douniasg
Do you have any pics of the dash lit up?
Old 12-21-2018, 08:12 PM
FourG63 97GST
on nice, I'm near you then, I'll be at pbir tonight, shoot me a PM or find me on IG: SoFlaZ06
Old 12-22-2018, 12:03 PM
douniasg
douniasg's Avatar
here is a little video
C5 Kirkland (12-22-2018)
Old 12-22-2018, 12:05 PM
douniasg
douniasg's Avatar
will do! I probably will take the c7 soon after I get it tuned . See if I can still bang gears.
Old 12-24-2018, 05:16 PM
jayyyw
jayyyw's Avatar
Looks great.
Old 12-29-2018, 01:37 PM
HardcoreABN
HardcoreABN's Avatar
would love some info on that 9" IRS diff.....
Old 12-29-2018, 08:18 PM
douniasg
douniasg's Avatar
It's a Dutchman irs that was solid mounted in the correct location . Then measured for correct axle length and drive shaft . Called up the driveshaft shop and they made the half shafts and d/s. The car has 10 point cage welded to the frame so I am not worried about the body structure without the torque tube. Will see how it works at the track maybe in March . I have done some trans brake burn outs and highway pulls all seem solid. I did switch from a Detroit locker to a spool. The rear was shifting when the locker was locking up and it didn't feel safe. Spool is definitely the way to go.
To Holly Hi Ram installed
Old 12-30-2018, 08:56 AM
HardcoreABN
i was looking at that Dutchman unit, but I was concerned about the mounting points on it. Hell, the ONLY real reason I want to go SRA is so I can have a 9" that won't cost eleventy million
Old 01-04-2019, 02:58 PM
C5 Pete
AMP Racing
Support Corvetteforum!
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11-'12
The Dutchman piece is nice. There are several manufacturers that make an IRS 9” housing now. Some Aluminium. Some fabricated. Lots of options now.
Old 01-05-2019, 10:06 AM
chuntington101
chuntington101's Avatar
Anymore pics of the rad : intercooler setup? Looks pretty cool!
Quick Reply: Holly Hi Ram installed
