What do your timing tables look like?
I'm getting the tuning dialed-in on my LS3-swapped C5 with a T-Trim.
Would you guys mind sharing your timing tables with me so that I have something to compare it to?
HP Tuner files would be great.
Also what kind of fuel you're running for reference.
Thanks in advance guys!!
A very fat man from California tuned my Z06 & T-Ttrim with this timing table:
I'd do it myself more smoothly nowadays.
Your C5 doesn't know it has now next generation LS3, but anyway, just increase cylinder volume, injectors and if with 2 bar CoS, VE of course.
And that fat man who promised to send me a base tune around early 2007, hey, I'm still waiting... Well, not really. Learned how to tune at that time and rest is history.
https://www.corvetteforum.com/forums...e-are-you.html
Received 1,248 Likes
St. Jude Donor '21
[QUOTE=Pekka_Perkeles;1599201347]A very fat man from California tuned my Z06 & T-Ttrim with this timing table:
What fuel are you using and are you using any meth?
[QUOTE=Toys4Life C5;1599205133]
Gasoline and no substitutes. :-)
It was tuned for best California gas with no meth injection. As far as I know. But that was a long time ago.
EFILive COS has an extra MAP based spark retard table (maybe HPT does also?). This is still my baseline spark table-- it's conservative and I plan to add a little timing when I get it on the dyno. 91 and methanol, I have not observed any knock etc.
RPM / MAP / Spark Advance
4000 / 125 / 19.5
5000 / 145 / 17.5
6000 / 171 / 15.0
6500 / 182 / 14.5
This is how many degrees of timing is removed based on MAP > 105 kPa
4000 / 125 / 19.5
5000 / 145 / 17.5
6000 / 171 / 15.0
6500 / 182 / 14.5
St. Jude Donor '21
I am not a pro - but.... Looking at this - one thing jumps out at me, seems like a lot of timing from .8 to 1.2 between 2000 and 3600 rpms. Seems like all the 22,23 and 24's in that area should be more like 14ish. Not that you should ever see a lot of boost at those low of RPM's but that seems like it would Knock away. Am I missing something?
Comments?
Comments?
Yeah it looks like he just took the NA table and just applied 16 to a 8 x 8 section or whatever that is...... one word comes to mind, lazy.
