How many times can you pin a crank?
Well, I think I'm on pin 3. Pulling the cover off to hopefully fix a leak. The last pin was with an IW balancer. Is there any chance I can realign it? Also, if I use the correct tools to align the cover, can the existing holes leak? I've got a brand spanking new OEM cover, seals, alignment tool, I dont want a leak. I don't know what I'm doing wrong, but I want to fix the leak.
Received 1,260 Likes
you should be able to realign it and use the existing pin hole that way you don't have to drill another one
Received 4,117 Likes
Get a piece of drill rod that fits your pin hole about 4-5 inches long. Use that as a guide to start and align the balancer onto the snout. Then switch over to your installer tool. I can't ever see a reason to keep drilling new pin holes.
