Impeller swapping.... or a hybrid blower
I googled it and literally find no info,
I’d assume mainly because most people don’t have the ability to do it or most sane people would just swap to a ysi
BUT.....
What are some obvious issues if I put a ysi impeller and housing on a t trim?
Yes, I know it literally won’t just bolt on... but I can make a new “hybrid” housing with v7 impeller to mount to a v3
I wouldn’t be able to spin it as fast due to step up ratios
probably need better bearings
i could make a stronger shaft if that’s a possible issue
I want more horsies and I don’t feel like dropping the cash to trade up.
BUT.....
I am sure with access to the right machines, design equipment for things like altering the volute to accept the bigger wheel and then make the pieces needed that it could be done. BUT with everything being smaller in the overall diameter of the housings and ability to flow air, I don't see the gains being worth all the work. Its not going to be just swap a couple things or make a few things. Sell your v3 and find a nice used v7 to keep the cost down. I am betting there will be quite a few v7/2200's available soon with the bigger head units coming out semi-soon(at least in the advertising).
