Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C5 Corvettes, 1997 - 2004 > C5 Forced Induction/Nitrous
Reload this Page >
Post Fire Disaster Rebuild: My 99FRC 2019 Build with 1400+whp
Old 06-11-2019, 02:07 PM
EGash
CF Senior Member
EGash's Avatar
Default Post Fire Disaster Rebuild: My 99FRC 2019 Build with 1350+whp
So in 2017-2018 I took a stock 99FRC, swapped in a built 5.3 engine with a VS S488 & 4L80E and ran 8.7's on C85 in a very streetable car.
Here's my previous build thread.
https://www.corvetteforum.com/forums...ld-thread.html
We had fun, won a few races, competed in the OKC Daily Driver for Street Outlaws race with Dominator behind the wheel and had a lot of fun.
Unfortunately during a pass at the track, one of the fuel fittings on the regulator loosened and started an engine fire that burned up most everything from the firewall forward.
For 2019 we planned a rebuild which would incorporate a roll cage, fire suppression, NHRA legal firewall, SFI 3.2A-15 Fire suit for me, as well as a new power plant and larger turbo to push the car into the low 8's (maybe into the 7's)
Here's the general rundown of the 2019 re-build and some pictures below for your amusement:
Engine (Built by Chip Estes, Estes Automotive, Nicholasville KY)
Dart Block 427
Dart CCW Crank
Manley I Beam Rods
Wiseco Custom Pistons
LJMS Cam
Rectangular (LS3) Port 6 Bolt Heads
Manley Valves
BTR Springs
Trend Pushrods
Athena Headgaskets
ProFlow Intake (with Custom Dual Fuel Rails by Me)
NW 92mm throttle
Dual Fuel Systems:
E85 in stock Tank(s) fed to 8x 80lb Deka Injectors via Walbro 485 in-tank pump and Magnafuel Regulator
Methanol in 5 Gallon Cell fed to 8x Atomizer 550lb injectors via Magnafuel Outlaw 1000 Mechanical Pump, Waterman/Bob Ette Cable Drive, & Magnafuel Regulator
Turbo System
Garrett GTX5020R-88mm 1.40T6
Tial 60mm Wastegates
Tial 50mm BOV's
Flowtech Up/Forward Headers
Shearfab T6 Dual 2.5" Inlet Flange
Vibrant/CX Racing Stainless/Aluminum piping
Drivetrain:
Rossler 4L80E
Extreme Automatics RMVB w/ Pro Tree Trans Brake
PTC 9.5" Non-Lock Convertor
RPM C6 ZR1 w/ Wavetrack Differential, DSS 300M Shafts, 3.42 Gear
DSS Axles
Suspension/Brakes:
TRZ Outlaw Tubular Front Suspension
TRZ Steering Column (The first one!)
TRZ Manual Master Cylinder Kit
Strange Front Drag Brakes
RC Comp 17x4 Wheels
MT Sportsman Tires
AFCO Front Double Adj. Shocks/ Coilovers
Menscer Motorsports Rear Double Adj. Shocks Coilovers
Baer Rear Tie Rod Ends
Strange Rear Drag Brakes
PFADT/AFE Spherical Bearings
PFADT Drag Sway Bar
RC Comp 15x10 Wheels
MT 275/60-15 ET Street R Tires
Electronics:
Haltech Elite 2500
Haltech Race Expansion Module
Haltech High Power Ignition Coil Kit (IGN1's)
Haltech Wideband
Haltech TCA8 (EGT's)
Haltech Boost Control
Custom Wiring Harness
Racepak IQ3 Dash
Safety
Bivins Racecars Roll Cage
Stroud Fire Suppression
RSM Parachute Mount Kit
Stroud Parachute
EGash is offline
Turpid porpoise (06-12-2019)
Old 06-11-2019, 02:11 PM
EGash
CF Senior Member
EGash's Avatar
EGash is offline
The following 3 users liked this post by EGash:
Irish31 (06-12-2019), niterydr (06-12-2019), Turpid porpoise (06-12-2019)
Old 06-11-2019, 02:18 PM
EGash
CF Senior Member
EGash's Avatar
EGash is offline
Old 06-11-2019, 02:20 PM
INSTIG8R
Junior Member
Good lord that's a sexy turbo kit. Awesome build
INSTIG8R is offline
Old 06-11-2019, 02:23 PM
EGash
CF Senior Member
EGash's Avatar
EGash is offline
Old 06-11-2019, 02:25 PM
Tool Hoarder
CF Senior Member
Tool Hoarder's Avatar
Received 1,963 Likes on 1,092 Posts
Subscribed.... excellent work. Why didn't you put the main hoop through the rear bulkhead wall directly on top of the frame rails? That's what we do in road race C5s. Tanks fit back in fine.
Tool Hoarder is online now
Old 06-11-2019, 02:34 PM
EGash
CF Senior Member
EGash's Avatar
EGash is offline
Old 06-11-2019, 02:40 PM
JoeyG
CF Senior Member
JoeyG's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Wow
you car was the one that led me to buying a CXRacing kit. Sucks about the fire. But the improvements are astounding so far
JoeyG is offline
Old 06-11-2019, 02:45 PM
EGash
CF Senior Member
EGash's Avatar
EGash is offline
Old 06-11-2019, 02:54 PM
Turpid porpoise
CF Senior Member
Support Corvetteforum!
Turpid porpoise's Avatar
Holy crap
Turpid porpoise is offline
Old 06-11-2019, 03:04 PM
EGash
CF Senior Member
EGash's Avatar
Ok, so now for the results:
On the Hub dyno it put down 1357hp through unlocked 4L80E at ~27psi boost.
At the track it's been best of 1.23 60', [email protected] and [email protected] It's also been [email protected] and [email protected] I'm still working on getting the car to 60' and make it through the 0.400-0.600 area without spinning. Once I get that sorted, then I'll work on getting more power in from 60' to 330' with the hope that it will run 7.xxx out the back.
Here's a few timeslips, pictures and videos from the dyno and track.
File Type: mov
File Type: mov
EGash is offline
The following 2 users liked this post by EGash:
Old 06-11-2019, 03:06 PM
Tool Hoarder
CF Senior Member
Great build... get some better quarter panels. Much better looking options out there.
Old 06-11-2019, 03:23 PM
EGash
CF Senior Member
EGash's Avatar
Thanks Man!
I have never seen it done like that. I gave the chassis shop pictures of several roll cages in C5's, and he did his work from there.
Originally Posted by JoeyG View Post
Wow
Thanks man!
Originally Posted by Turpid porpoise View Post
Holy crap
I'll take that as a compliment.
Those are actually Glass/Carbon rear quarters from a CF Vendor (I don't remember who, it was over a year ago when I bought them) They took a considerable amount of time with a body saw and sander to make them fit. One of my friends suggested I leave the flare exposed Carbon, so when we painted them we tried it to see how it would look. My painter said if we didn't like it, he could always paint it solid. I'm considering having him repaint them with only half of the flare exposed carbon when he retouches a few other parts. Which other rear quarter options are you referring?
EGash is offline
Old 06-11-2019, 03:29 PM
Tool Hoarder
CF Senior Member
Here's a few pics of my road race C5Z just to show some differences. If you fit in your car it's moot. I'm 6'4" and needed every inch. Check out TPE and Lewis5 for full replacement quarter panels. I think there are another 2 vendors out there now.
Old 06-11-2019, 03:57 PM
EGash
CF Senior Member
EGash's Avatar
Thanks. That Ignited my memory. My rear quarters are Carbon Creations Carbon Quarters from Quik Z06 on the forum . http://corvettecreationz.com/product...-z06-frc-vert/
I'm 6'1" and 370lb. We lowered the wide Kirkey seat to the floor and I fit really well into the car after doing that. Getting In/Out sucks, but once I'm in it's comfy.
EGash is offline
Tool Hoarder (06-11-2019)
Old 06-11-2019, 07:21 PM
jayyyw
CF Senior Member
Wowowowowowow!!!! This build is amazing.
jayyyw is offline
Old 06-11-2019, 08:53 PM
neutron82
Bangin' Gears
neutron82's Avatar
damn... badass man and thanks for all the pics
neutron82 is online now
Old 06-11-2019, 09:18 PM
fisher auto
CF Senior Member
fisher auto's Avatar
Outstanding!
fisher auto is offline
Old 06-11-2019, 09:57 PM
ForceFedC5
CF Senior Member
ForceFedC5's Avatar
Awesome build!
May I ask what the 4L80 is rated at? I was thinking of going that route but heard powerglides are much stronger?
ForceFedC5 is offline
Old 06-12-2019, 12:28 AM
ascastil
CF Senior Member
I know what pics I'm falling asleep to tonight.
ascastil is online now
Quick Reply: Post Fire Disaster Rebuild: My 99FRC 2019 Build with 1400+whp
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
