The ultimate trans/ diff package. Billet sequential with quick change rear end
I might be interested in buying your old transmission and differential for added convenience.I'll be adding more pictures as I am able. Please do not call the shop. PM me directly for help with this package and if needed I'll set up a time for a phone call where we can discuss things at length.
This is the integrated oil pump for spraying the gears directly. The spray bar is machined into the case.
The billet shifter is offset to allow the driver to set the shifter in the most comfortable position. They are offered with different offsets, up to 4", creating an 8" allowable variance from side to side or front to year. That is actually larger than the hole in the tunnel will accept for our Vettes though. a 2" offset will be more than enough.
Notice the differential is supported at both the front and rear, by the front and rear of the factory cradle. The billet mounting brackets in the rear are easily installed in minutes.
billet rear cover for the quick change differential.
behind the support rail, lies a load cell. The placement and quality of this load cell means that you won't end up having to have some 2' long shifter in order for it to work.
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
this is a truely awesome piece of engineering. You continue to push the limits of the platform. I have a customer that's seriously interested in doing a 4 wd vette at around 2500-3k hp
he's running a sonny leonard 555 all alum BB that will likely get a pair of big turbos. He is looking for a tranny that will hold that kind of hp
currently he's trying to do this frankenstein build on a c4, but I'm pushing him to the c5 as it will be easier to do.
One of my "frankenstein" projects is to run twin electric motors up front (300 each) to make that 4 wd more feasible. This system will feature an array of super capacitors rather than batteries to be a
"redneck KERS" I'm looking to do some custom motors for this and use CF printing for the motor armature and case to keep the system light, and run in board brakes (CF) to dramatically lower the unsprung
I also have a concept for a multi disk inboard brake system that goes right on the end of the shaft of the elec motor to reduce unsprung weight.
This will go into an old C5 as they are cheap and easy to work on with the steel frame and still light enough to work. I'll give you a call as this high end stuff is still cheaper than the c8 and it will GO
one more thing to bounce off you in the interest of big furry ponies. I whittling out some alum billet parts that bolt into the block to convert it over to 6 bolt.
the block also needs machining to cut the "access windows" in the valley to get to the inboard bolts. This setup is inspired from the old ERL supedeck GM block conversions but is all bolt in rather than welding.
I'll send you a set once I get it all figured out and running making big spank this winter. I'm trying to upgrade the t3/t4 turbos with bigger wheels to get to around 1200 at the engine. I have the champion down pipes and I'm converting a c6 z06 3" exh to fit the c5 to priovide a nice straight through free flowing exh at way cheaper prices than the rip off c5 stuff. OBX c6 z06 system was dirt cheap in comparison.
seasons greeetings, boost a muv!
Here's some add'l information:
The top chart is the differential gear chart for each pair of gears. (85.00 per pair) The bottom chart is based on one of my gear sets for playing at the 1/4mi track.
these pieces are so over the top I need to sell a kidney! this would go with my turbo build and finally allow me to ditch the 4l65e
it's good for going fast, but this brings back the gears!!!
I'm in the same boat my man. Finally a solution to put down all those big ponies for those less challenged in fold that you and I my friend.
Gonna have to pimp out both daughters and the Ms to afford this one. Time to get to steppen gals, daddy needs a new tranny!!!
i needed the tag because I got distracted from this conversation for a moment so thanks for that!
Brent, as I look over this box and my home eq loan winces in pain, I have a cheaper idea
whittle out some mounting ears for the stock tranny like those. one plate that goes all the way across for the base
and a mounting ear like these for the tranny on each side. I think that would be a low cost bolt on upgrade for us more light of wallet.
