P1541 Error code
Old Mar 2, 2004 | 11:35 AM
Als98C5's Avatar
Als98C5
Default P1541 Error code
After I had the SuperCharger installed I went through all the error codes and cleared them all out. I am unable to clear the P1541 error code, it keeps coming back as a H (history) code. I know the P1541 is a Torque management code which was no doubt generated by the addition of the Magnusson. How can I clear it?
Old Mar 2, 2004 | 11:41 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: P1541 Error code (Als98C5)
If you can already view the codes in the DIC, you're half way there. Press RESET once to get to manual diagnostics, then press OPTIONS to scroll through each individual code category. When you see a category that has the codes you want to erase, just hold RESET for a few seconds.
Old Mar 2, 2004 | 11:47 AM
Als98C5's Avatar
Als98C5
Default Re: P1541 Error code (diynoob)
Thanks, I am able to reset it, and erase it, but it comes back
Old Mar 2, 2004 | 12:21 PM
ICULUKN-C5's Avatar
ICULUKN-C5
You need someone with LS1 edit to adjust the torque management setting in your PCM.
Old Mar 2, 2004 | 02:20 PM
Als98C5's Avatar
Als98C5
Default Re: P1541 Error code (ICULUKN-C5)
Thank ICU
It doesn't appear to be causing any problems. How big a deal is this alarm?
To P1541 Error code
