Custom Procharger moddification.
Old Apr 10, 2004 | 09:03 PM
c5guy4life's Avatar
c5guy4life
Default Custom Procharger moddification.
Is it possible to keep the stock fans and route the intake for the procharger over the radiator by cutting some of the radiator shroud plastic and using a longer coupler like 4-5" bending it up and around a tad
[Modified by c5guy4life, 8:04 PM 4/10/2004]
Old Apr 10, 2004 | 09:29 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Re: Custom Procharger moddification. (c5guy4life)
You need to contact Andy at aandacorvette.com !
Ask about his bolt-on mod to lower the stock radiator.
You might think about a front mount single IC from him also.
Roy
Old Apr 11, 2004 | 02:36 AM
c5guy4life's Avatar
c5guy4life
Default Re: Custom Procharger moddification. (7.0sc SuperVette)
too much money i already talked to him.
Old Apr 11, 2004 | 08:33 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Yes you can do that.
VR
Old Apr 11, 2004 | 10:05 AM
EatRice's Avatar
EatRice
Default Re: Custom Procharger moddification. (vetterdstr)
There is a shop In Valrico,Fl that does that cars with the standard ATI Dual intercooler set up. You can move the radiator and put back on the dual fans then mount an air filter to the procharger however you like. He puts K&N filters directly onto the charger with no pipe.
To Custom Procharger moddification.
