I routed it through the tunnel for the driveshaft tie straped to the drivers side and straight to alternator.
Just use a wire or line to feed through first and then pull the harness forward and to the alternator.
mount the fuse on the fame bolt near the alternator!
Good luck!
Tony
This reminds me...(I should put a spare fuse somewhere just in case!!!!!!!!)
