The PT52 turbos came in last Thursday. Mike (Xtreme) does the tuning and is racing NHRA the weekends in March. I think they plan on getting her back on the rollers this coming Tuesday. I am happy with the numbers on 91 octane and 9lbs, it will be interesting to see what the 13-14lbs boost range yields on higher octane. I am hoping max boost will be reached between 3200-3500rpms...what do you think about the PT52s Phil???
In a nutshell? Atleast your in the zipcode now. Depending how its been speced out might even be close .
I have not seen specific compressor or exhaust maps on that turbo as PTE seems people must not want them .
I do know the compressor side specs like a T04e-60trim. Which is pretty close but the effeciency and displacemet of the LS1 pushes is out of the sweet spot quickly but not horrible. The exhaust side, thats a wild card. My guess based on the long header run and the typical exhaust wheel from that family (t4 version) is that it will be soft. But thats not a bad thing. There are a lot of different wheel/housing combinations on top of how it reponds ti difference in exhaust systems feeding it.
But, its much closer and something that would be a great point to learn from.
Maybe Jose can provide a map for the 52? The 51 is a T04E-60trim wheel and the 52 is a slightly larger wheel.
Phil
The te-44 on paper are in the same range as the pt 51/52.
The te44 has the same compressor wheel at the pt51 and may have the same issue with operating out of the sweet spot. But, changes in the cover etc will change the map.
I do suspect that if you got the t31 frame (t3 based) that it will spool pretty well, potentially maybe better than the PT series.
Phil
Phil
Its my understanding that there is very little difference between the PT51 and PT52...PT51 uses a 3 bolt (buick style flange), they went with a PT52 because it comes with the T4 flange...supposedly not much difference between the PT52 and PT51, but like you I have not seen a map for any of the PTE turbos..all I know is they have garret internals and PTE uses their own housings.whatever...I won't know until its back on the dyno.
The PT52 has a different compressor wheel. Slightly larger infact that the TE-44.
If you can find a map for an SC-6027E,SC6030E or SC5252E The all use the 2.320"x 3.000" 60 trim Garret wheel.
Take a look at innovative and others that are using the same wheel and cover for a map. If you find it post it up.
Also,
If you look at your data from your cars current turbo you can look at how it responds and apply the data to the new maps. If I take data from the Stage X map and overlay in on the compressor of the TE44 its just out of the sweet spot. Cetrainly worth a try to see how it responds in your system.
Phil
phil i am a newbie w/turbo stuff so please bare with me. the te44 is a t4 exhaust housing so is it possible to "just" switch housings to t3? then making it t3/t4 hybrid? if so i cannot imagine it being that difficult on the ptk kit.
The TE44s typically use the T31 style turbine wheel. Its basically a T3 wheel and much smaller that the equivalant T04 based wheel. They typically spool much faster due to its weight and wheel size. If the ones your using are built different than the Buick style specs then I dont know whats on the exhaust side.
Phil
alright then, does the ptk header allow you to go from t3 to t4? i would think that thats pre determined.
This might help you guys.
This is a t04e-60 (PT-51) compressor map with 1 data point put on it.
The data point is 9psi and 346cui LS1 making approx 600rwhp.
If you make less power at 9psi then move the data point left on the pressure ratio axis.
If you add displacement or make more power at 9psi then move it right on the pressure ratio axis. Object of the game is to target the high efficiency island through out the operating boost range.
Phil
What variables are you using to compute your pressure ratio and air flow? Are you assuming sea level? What is the max rpm you are using for the calculations? Also just so people aren't confused your post about moving to the left or right should say air flow axis not pressure ratio axis.
