what head gaskets for 6.0L heads and 5.7L block
anyone who uses the 317 casting heads and forced induction, what head gaskets are you using? Do you have the p/n?
Use a 6L (MLS) gasket for a 6L head... GM part # 12569365. It does not show up on GM Parts Direct website but I know it to be a valid GM part number... as I have the gasket sitting in front of me...
Bill
Bill
Why do some tuners use Conetic (spelling is wrong I know) and others use MLS. Is one that much better than the other. I know my tuner picked the Con. ones for my 6.0 heads. I think MDMC using Con. also.
Jon
Jon
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,084 Likes
Jon
Jon
That would explain why you sound like you have a clue once in a while..
bahahahaah
GM MLS gaskets all the way when possible. And they are dirt cheap compared to others.
Phil
bahahahaah
Phil
Oh well, since my engine is built I am stuck with my Con. gaskets at this time. Is there any negative to having them? I will only have 10psi with my FI. See, I learned something new again...Thanks Doug...wait I mean Chris... & Phil.
JOn
JOn
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
bahahahaah
Phil
bahahahaah
Phil
Jon,
Cometic gaskets are a great gasket. Hell, we've pushed 14psi of boost through a Darton Sleeve block with a 4.125 bore and the Cometic MLS gaskets held. But I agree with Phil... GM produces an equal quality, if not better, multi-layer steel gasket.
Bill
Bill
