NOS , Injector question?
Old Jan 3, 2005 | 11:53 AM
Blue Flame-less Joe's Avatar
Blue Flame-less Joe
Cruise-In VI Veteran
Cruise-In VII Veteran
Default NOS , Injector question?
I'm shooting a 100 dry shot with stock injectors on a 2000. Are stock injectors ok? what if I went to a 125 shot? If not what size injectors should I go to and where should I buy them from?
Old Jan 3, 2005 | 12:02 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
'99's and '00's had the smaller 26# injectors. All other years have 28#'ers. I'd say at a 100 shot you are maxing out, or close to maxing out the stock injetors but only an autotap/HP Tuner data log would show that.
Without datalogging/dyno'ing you are rolling the dice going any higher IMO.
Old Jan 3, 2005 | 11:26 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Even the 28lb's are running it close on some engines running the 125hp dry jets, but some are fine also.
Old Jan 4, 2005 | 10:05 AM
Blue Flame-less Joe
What would be a more than safe size to run with a 125 dry shot and where can I buy some?
Old Jan 4, 2005 | 10:26 AM
5 Liter Eater
St. Jude Donor '11
The problem now becomes cost. In order to spray over 100 dry you need new injectors and a tune to go with them. If you're going to do that I'd say you may as well go w/ 42#ers which is more than you need to spray 125 but you may as well plan ahead. Between the cost of injectors and a tune you would be better off buying the parts to convert the 5177 to a wet kit from a cost perspective. It would be much cheaper. There are guys spraying over 200 dry with big injectors and a nitrous tune so it is definitely possible but it is cost prohibitive IMO.
Old Jan 4, 2005 | 11:03 AM
Blue Flame-less Joe
Should I get it tuned with just a 100 shot? I'm not planning on using it alot just at the track some of the time. For most of my bracket racing I will just run on motor.
Old Jan 4, 2005 | 11:50 AM
5 Liter Eater
St. Jude Donor '11
I would say no. There are plenty of people spraying 100 dry without issue. The only thing that is of concern to me is the smaller injectors in the '99 and '00 model years. I ran the fuel injector worksheet at http://www.rceng.com/technical.htm#WORKSHEET and plugged in 450 crank HP (100 shot), 8 injectors @ 60 PSI and a BSFC of .55 and it said in order to support 450 crank HP the 26.6# injectors need to run 99% duty cycle so theoretically you're maxing out but I would say you're more than likely OK @ a 100 shot. Changing the BSFC # by a small amount will alter the injector requirements significantly and real world testing would need to be done in order to get an accurate BSFC #.
Perhaps someone else running a dry kit can comment on their injector size and duty cycle and horsepower for a particular shot from a datalogged dyno run which would give us a more accurate BSFC # for a dry nitrous LS1.
Note that RC rates static flow of injetors at 43 PSIG if you decide to play with the BSFC worksheet so at 60 PSIG a 26.6# injector would be 22.5# and a 28.8# injector would be 26.7#.
This worksheet is what made me shy away from a dry kit.
Old Jan 4, 2005 | 12:32 PM
5 Liter Eater
St. Jude Donor '11
I tried playing w/ the BSFC worksheet for a bit before I realized that we NEED to know what the duty cycle was for someone's N2O assisted pull to get the BSFC. The same would apply to calculating a NA or FI LS1's BSFC.
Old Jan 4, 2005 | 11:13 PM
Robert56@RNS
Collections Hold
One thing to keep in mind is that if your running a NOS brand dry kit, they rate their jets at the crank. So, a 100hp shot is really about 80hp at the rear wheels. This is one of the reasons these kits are so safe: over rated hp figures for a conservative set-up. Now if you want to run 100hp shot at the rw use dual .036 n2o jets=97.75hp (115hp at crank minus 15%), assuming it's a nos kit. Every .001 jet size increase equals a 2.5hp increase.
To NOS , Injector question?
