Installed Halltech Trap
Old Feb 3, 2005 | 09:28 AM
Bman's Avatar
Bman
St. Jude Donor '05
Default Installed Halltech Trap
Engine light is now on. Is this normal until the computer adjusts or
is something wrong?
Old Feb 3, 2005 | 09:33 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I see from your profile you have a Z06, this has been a problem with the Halltech Trap and Stinger... it's probably a lean code due to the fact that the Z06's don't have a screen in the MAF(mass air flow sensor) so there is too much air getting in and the computer cannot compensate to adjust.
A good number of Z06 folks have had this problem with the Halltech...I am not sure what the fix is,,maybe double check all your connections make sure nothing is loose,,other than that I guess only a tune would help fix the problem.
good luck
Old Feb 3, 2005 | 09:43 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
with the above. Let's hope others have an answer for you. But in either case keep us posted.
Old Feb 3, 2005 | 01:04 PM
Nick 02 Z06's Avatar
Nick 02 Z06
My understanding is that this isn't supposed to be a problem with the TRAP system. I'd go through all the connections again and see if the light goes away.... Good luck
Old Feb 3, 2005 | 01:14 PM
C6~Missle's Avatar
C6~Missle
is something wrong?
Check your install... Only the 04's are throwing codes with the Halltech...
Old Feb 3, 2005 | 02:32 PM
Bman's Avatar
Bman
St. Jude Donor '05
Thanks fellas..
good luck
On my 01 Z there is a screen on the MAF
To Installed Halltech Trap
