first oil change
Old Apr 16, 2005 | 08:00 PM
AndrewNguyen's Avatar
AndrewNguyen
Default first oil change
just wanted to share, i just did my first oil change on the vette and it was pretty easy until it came to the oil filter.I didn't have the wrench that removes it so I had to do it by hand and it was pain.It was stuck so I had to take a screw driver and hammer it in and used the screw driver as a handle to twist it off.
Old Apr 16, 2005 | 08:32 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
buy one of those wrenches that cup over the end and use a ratchet
Old Apr 16, 2005 | 08:38 PM
army2000's Avatar
army2000
St. Jude Donor '11
OMG, you're sick!!! This is a Vette not a '78 Pinto. Maybe you should of took a hacksaw to it. Just by curiosity how did you get the new one on???
Old Apr 16, 2005 | 09:40 PM
Dave68's Avatar
Dave68
I have four different types of oil filter wrenches for the many different configurations of oil filters I need to remove. I believe I use the one with the nut and square hole at the bottom when I remove my C5's filter. However, in years past (with other vehicles), I have used a screwdriver when the right wrench was NOT available. The filter case is surprisingly thin and is easily punctured by the screwdriver tip.
Old Apr 16, 2005 | 09:45 PM
vder's Avatar
vder
Walmart carries the orange cups in different sizes that fit to your application needed. Much easier that way.
Tim2K4Vert's Avatar
Tim2K4Vert
I had to do that for the first oil change on my '04. I have one of those wrenches that fit over the bottom and I just couldn't turn the filter with it. The damn thing was on way too tight. Screwdriver worked great!
Old Apr 16, 2005 | 11:16 PM
Shylor's Avatar
Shylor
A strap wrench would of worked.
Old Apr 16, 2005 | 11:49 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
Old Apr 16, 2005 | 11:53 PM
AndrewNguyen
i had a strap wrench but it was too big
Old Apr 16, 2005 | 11:55 PM
NSTG8R's Avatar
NSTG8R
i hand tighten and loosen mine.
to each their own .. i guess.
jrose7004's Avatar
jrose7004
Oh well, congrats on doing the job!
Old Apr 16, 2005 | 11:59 PM
uknowme2good's Avatar
uknowme2good
why do u think god gave ou two hands??? One to change the oil with and the other to drive with
Old Apr 17, 2005 | 01:07 AM
Vette#2's Avatar
Vette#2
Here is a trick I learned from sticking oil filters on my boat. Don't use oil on the sealing gasket, use good old Vasoline or grease. Vasoline is cleaner to use & your next filter change will be a plesant suprise!
Old Apr 17, 2005 | 01:54 AM
KHM_70's Avatar
KHM_70
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Andrew,
My advice – take it or leave it.
Use this filter
It's a K&N HP-1007 and has a 1" nut on the bottom. One of the best oil filters made and very easy on-off
To first oil change
