Vette shut down.
Old Apr 21, 2005 | 09:20 AM
wolfman04's Avatar
wolfman04
Default Vette shut down.
Took Vette out yesterday for a ride drove around 20 miles pulled out from a stop sign I jumped on it, car starter to take off and then the car just acted like it turned off it just died then picked back up and ran fine.Got home check for cods, found one it was B0516 Speedometer Signal Circuit Malfunction H everything else was OK anyone know what made this happen. Thanks
Old Apr 21, 2005 | 10:04 AM
v.vet's Z06's Avatar
v.vet's Z06
I don't know what made it happen to you but happened to me last Saturday going up a rough interstate ramp. I jumped on mine with T/C on and at about 40mph there was a momentary shutdown. Just assumed T/C had kicked in for some reason.....maybe tire slip. The T/C light didn't come on....it happened and resolved that quick. Have no way of checking codes. The shutdown was 1-2 sec then full throttle again to 75?
Old Apr 21, 2005 | 10:16 AM
JNS's Avatar
JNS
St. Jude Donor '06-'09
Probably the traction control. The other night mine did that when I went over a rough expansion joint while accelerating and it caused the rear wheels to slip a little.
Jeff
Old Apr 21, 2005 | 11:07 AM
SilverRoadster00's Avatar
SilverRoadster00
If you have a DIC, you can check codes. turn the key to run - don't start car - hold down the OPTIONS button and while holding, press FUEL 4 times within 10 seconds. the DIC will then scroll through all the modules and any stored codes. Go here for more info:
http://www.stengel.net/diccodes.htm
To Vette shut down.
