Coolant leak??
Old Apr 27, 2005 | 07:47 PM
vettmanjj's Avatar
vettmanjj
Default Coolant leak??
For about the past 4 weeks I've noticed a coolant smell inside the car when I start my 2000 C5. This suggests a slight leak in the heater core, but I've not had to add anti-freeze, nor have I found a damp spot on the passenger side carpet. Has anyone else experienced this, and if so, what was the source of the smell/leak. Thanks
Old Apr 27, 2005 | 08:16 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I agree that it is usually a leak in the heater core. It may not be big enough to show externally - if you put the defroster on does the windshield fog? Check the heater hoses too.
Old Apr 27, 2005 | 08:36 PM
vet85's Avatar
vet85
no1 if u want to see for sure if its the heater core (which it is about 99 percent chance it is )go to a radiator shop and pressurize the system .also if your windshield gets a film on the inside kinda like a fog its the core.remember when these things start to leak it is ever so small of a leak.it could take months for u to notice it .just my opinion but ive been checking cooling systems for about 30 years and if u can smell it in the car but cant locate it ill bet u its the heater core ...go get it pressurized and youll know for sure ...good luck .
Old Apr 27, 2005 | 09:42 PM
vettmanjj's Avatar
vettmanjj
Thanks for the responses; time to take advantage of my GMPP coverage. Hate to think what this repair would cost--lots of labor getting to the heater core.
To Coolant leak??
