Additional information for installing the STS-2C5PW harnesses into Euro fixtures
- There are several manufacturers of Euro style tail light fixtures, and each have their own design. Some of them are designed to accept a #3157 wedge style lamp, which is the same as the stock Corvette brake/turn/tail lamp. Others are designed to accept a #3156, which is a single filament lamp, typically used as a back-up lamp. And still others are designed to use a #2057 bayonet lamp.
The STS-2C5PW harnesses are designed to be installed into a socket that uses the #3157 dual filament lamp. If your Euro fixtures use the #3157 lamp, then you can install the STS-2C5PW harnesses to achieve Sequential Turn Signal action.
It depends on the type of euro harness you have -
gredmer -
good deal! I got to follow my wife the other day while she was in her vette - the seq's are a riot! Now someone has to mod an instrument cluster to install two signal indicators so the dash lights can be sequential....
