Headlght Instal
Old May 3, 2005 | 09:13 AM
FastAssVette's Avatar
FastAssVette
Default Headlght Instal
Sorry for the same question, but i have lost the original post. I just pick up a set of silverstars and i would like to install them. Any suggestions for a easy intalation. thanks Again Bud
Old May 3, 2005 | 09:22 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
remove headlight bezels reach in and twist.....be VERY careful installing new lights so you DO NOT bend the little tabs that secure the bulbs....you will know because the lights will be aimed wrong....and you will end up pulling the whole damn thing out to fix...dont ask how I know...
Old May 3, 2005 | 09:23 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
1. Remove the three screws holding the plastic bezel around the headlight assembly.
2. Pull the bezel forward (the top part has a tab holding it to the headlight cover)
3. Hold the sides and tilt the bezel downward and pull it out.
4. Reach behind the light reflector and unscrew the bulb.
**Before you do #4, check the orientation of the bulb, as well as the the orientation of the lock tab. You have to press the tab in order for you to turn the bulb.
Good luck
gredmer's Avatar
gredmer
http://forums.corvetteforum.com/show...l&forum_id=103
Your old thread.
To Headlght Instal
