[Z06] Royal Purple Syncromax to the rescue!!
Old 05-18-2005, 08:13 AM
Innovator
Innovator's Avatar
Default Royal Purple Syncromax to the rescue!!
I really hated the way this car shifted. After I bought it, I thought to myself, "what the hell did I do?" I bought a beautiful car with a truck transmission. One of the main reasons I sold my modded 30000GT VR4 was to get a car that shifted smoothly. I was more than willing to give up 200 HP to have a smoother shifting car.
Anyway, a few weeks ago I filled the trans up with RP Syncromax, and I'm happy to say that the difference was substantial!!.
At first, it wasn't that noticeable. But after a couple of days, it's like a different transmission. Shifting effort has been reduced a good 35% at least. it's almost hard to believe. I hope more of you guys give it a try.
Rick
Old 05-18-2005, 09:20 AM
Z06-JIM
Z06-JIM's Avatar
Cruise-In VII Veteran
Thanks for the review. I've been trying to decide which brand to use in mine.
Read quite a few good reports on the RP Synchromax, I might just have to give it a try.
Old 05-18-2005, 10:49 AM
RoHo
RoHo's Avatar
I changed to RP a couple of months ago and I could feel the difference on the first shift, I give it two thumbs up.
Old 05-18-2005, 12:16 PM
zulatr
zulatr's Avatar
Any effect on the warranty if you change to a non-GM certified lubricant?
Old 05-18-2005, 12:46 PM
Innovator
Innovator's Avatar
Not if it meets the specs, which it does.
Old 05-18-2005, 02:46 PM
0260IN4
Cruising
0260IN4's Avatar
Where can I find RP? online or would Pep Boys, Chief, or other auto parts store carry it?
Old 05-18-2005, 03:27 PM
sandmanusd
sandmanusd's Avatar
How do you drain the tranny fluid to switch it out?
Old 05-18-2005, 04:13 PM
Innovator
Innovator's Avatar
You remove the drain plug on the bottom of transmission.
Old 05-18-2005, 04:14 PM
Innovator
Innovator's Avatar
PeP Boyz can order it for you.
Old 05-19-2005, 12:05 AM
TheDVS1
TheDVS1's Avatar
Summit Racing has it for $7.75 a quart. How many quarts do I need, and I presume I just fill to the bottom of the filler-hole? Thanks...
Old 05-19-2005, 10:16 AM
RoHo
RoHo's Avatar
Napa also has RP products
Old 05-19-2005, 10:21 AM
l2vette
l2vette's Avatar
What is the difference between Royal Purple and Red Line. Is one better than the other??
Old 05-19-2005, 12:36 PM
GOLD72
GOLD72's Avatar
Received 1,106 Likes on 718 Posts
I changed over to Red Line D4-ATF over 30k miles ago. I would have to say that the shifting improvement is only marginal over the factory fill Dexron mineral oil including cold weather performance. I too would like to hear if the RP is better than the Red Line.
GOLD72
Old 05-19-2005, 05:13 PM
Z06ufgrad2002
Z06ufgrad2002's Avatar
GOLD72
I switched to Red a long time back and got no improvement over the OE fluid.
Old 05-19-2005, 07:08 PM
RoHo
RoHo's Avatar
Give that Royal Purple Syncromax a try, you will notice a change in your transmission, I'm no RP salesman, it's just that this stuff does makes a difference.
ArmchairArchitect (05-04-2017)
Old 05-19-2005, 09:10 PM
wannabe-psi
----snake bitten----
Support Corvetteforum!
wannabe-psi's Avatar
Rick
are you the same "Innovator" from the 3s forums??
Old 05-20-2005, 06:41 AM
chiefDave
chiefDave's Avatar
St. Jude Donor '05-'06
http://www.thunderracing.com/catalog...&vid=7&pcid=75
I am looking into this too. PIA to change yes? Any ball park gues on how much to change?
Dave
To Royal Purple Syncromax to the rescue!!
Old 05-20-2005, 10:12 AM
RoHo
RoHo's Avatar
Four Quarts
Old 05-20-2005, 11:57 AM
chiefDave
chiefDave's Avatar
Originally Posted by RoHo
Four Quarts
Thanks brother! Ummm sorry but I was trying to ask how much for the labor to get it changed if you bring your own oil. Sorry for my unclear post. Damn I need a drink !
Dave
Old 05-20-2005, 12:21 PM
C5Longhorn
C5Longhorn's Avatar
I'm about to pull the trigger on this as well and was also wondering about which brand to go with. I'm leaning towards the RP right now.
Quick Reply: [Z06] Royal Purple Syncromax to the rescue!!
