So to get a little more pep, all I need to do is change the rear end gears from what I have now (not sure what I have but know its stock 2001) to a 3.42? Not going to race it and don't want to break the bank, just a little more pep.
Depends on what you currently have. If you have a stick you already have 3.42's. If you have an auto, you either have 2.73 or 3.15's. If you have the former the switch would give you a huge kick in the pants. 3.15's to 3.42's isn't a significant amount.
...Or just keep your eyes open here for a used rear for much less moula.
Yeah, that was what I was referring to. Seen then for a few hundred. But pretty sure having to pay for labor will run you quite a bit more. Not sure this is a diy job for less experienced folks.
