So how much drag coefficient is increased w/ the headlights up in the C5?
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by RJH20dog
I'm curious....you planning on driving over 170 MPH at night?
Seriously, I was curious too, because I am really thinking about getting fixed lights, because I am not a huge fan of the buildings that pop up when I turn on the headlights.
Get Some!
Originally Posted by ls1vette97
I wonder how much it really effects top speed?!? If it's alot I'm going to have to look into some bright foglights!
tried going down a hill (the grapevine in so cal) with them up (but not on) and down. The difference was huge! Coasting for three miles at a 6% grade with the lights up, the car stayed at 85 or so. With them down, it went more than double digits. I hate the pop-ups
St. Jude Donor '06-'07-'08-'09
Eject, Eject, Eject
My guess is at 175mph when you pop the headlights, they'll quickly separate from the car. Then the two big holes where the lights used to be will allow enough air into the engine bay to separate the hood from the vehicle. Once the hood is gone, the airflow will build up against the firewall until it punches thru and impacts under your seat. At that point, your seat will eject thru the targa top and you've successfully egressed your cockpit. Total time from turning the switch to driver separation is 1.5 seconds. Built in low tech ejection system!
I imagine you could top out your velocity in 6th gear where drag overcomes horsepower and then pop your lights. You should see a significant decrease in your top speed. You could then move the switch to parking lights leaving the housing popped up to isolate the electrical system. Your velocity should then slightly increase with the reduced electrical load.
It's an interesting question, for the science of wind drag, and coefficient of friction, and down force (ie from rear spoilers, at speed).
Lots of wind tunnel testing, I remember reading, when C5 was being developed and engineered. I think C5 set some new standards (at that time) for wind tunnel efficiency, I recall reading. I do not remember reading about how the headlights up, effected the wind tunnel efficiency.
But I'd think it has no 'meaningful' effect at all, except at high speeds. Same thing with rear spoilers, have little effect at slow or cruising speeds. Actually, I read that spoilers, are 'inefficient' at low, or normal speed, simply creating drag without useful downforce. I imagine the same would apply to headlights in the up/on position.
Who runs top speed in a C5 Corvette at night? Unless you are in a 24 hour Lemans type race, I suppose....
Most speed runs, and races, at track events I've ever seen were in the daylight. Drag strips are mostly lighted for night events, (at least the ones I've been to were).
Of course, there is amatuer night, when the drunks and fools are out amongst us.
Don
Don
