Removing side mouldings?
Old Aug 1, 2005 | 09:12 PM
Derf's Avatar
Derf
Default Removing side mouldings?
Is it hard to remove the side mouldings? Paint damage? Pics of removed would be nice? Thanks
Old Aug 1, 2005 | 09:20 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
i used a heat gun and fishing line.. after, 3m adhesive remover, claybar, and wax..
before
after
hope this helps
Old Aug 1, 2005 | 09:30 PM
Zoso1951's Avatar
Zoso1951
St. Jude Donor '05-'07-'08-'09
Default sequence of events?
So you heat up the mouldings, and then floss them off with fishing
line, clean up with goof off or similar, then clay and wax?
I'd like to remove mine too. I think they look much better without them.
Old Aug 1, 2005 | 09:38 PM
QKSLVR Z's Avatar
QKSLVR Z
it's better with 2 people.. one uses the heat gun while the other uses the fishing line to "saw" away at the double sided tape
Old Aug 1, 2005 | 10:11 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
before
after
hope this helps
Exactly what I did except I just used a hair dryer. I'll save the pix as I also have black... just a vert instead.
Do it. Just take your time. Getting the adhesive off is by far the worst part of the job.
Old Aug 1, 2005 | 10:14 PM
QKSLVR Z's Avatar
QKSLVR Z
Old Aug 2, 2005 | 12:30 AM
Shylor's Avatar
Shylor
It only took me maybe 30 minutes to remove my "MOLDINGS".
Old Aug 2, 2005 | 12:31 AM
xjcharity's Avatar
xjcharity
St. Jude Donor '21
Old Aug 2, 2005 | 05:31 AM
Dave1's Avatar
Dave1
St. Jude Donor '09
...I had to get rid of mine too........I like em clean......
Old Aug 2, 2005 | 06:38 AM
That's pretty much the procedure.
Old Aug 2, 2005 | 07:20 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
We used weed eater line on Not-Mee's car last weekend, and they were off in 30 seconds. No heat gun. Then a little bug and tar remover to take off the residue from the foam tape.
Old Aug 2, 2005 | 07:38 AM
ebubman's Avatar
ebubman
looks mucho cleaner without the bsm. bub
To Removing side mouldings?
